Guest1287's Avatar
Porsche Crest K&N Filter Problem
Ok, I bought a K&N filter for my 1986 944 Turbo. After I installed it the hood would not close. Has this happened to anyone else? It seems the that the K&N filter has a bit more height than a Mahle air filter. Is there any way to fit this sucker in there?
Old 03-30-2012, 09:48 AM
89-944NA's Avatar
Location: In a dumpster behind Albertson's in Los Angeles County
Send a message via Yahoo to 89-944NA
Did you get a cone filter, or is it the filter that goes in the filter box in place of a stock filter?
1989 944 NA Glacier Blue - SOLD IT
1989 944 S2 Alpine White T-Boned (totaled) by a lady dressed in a CLOWN costume (RIP ) Apr 89 - Mar 08
1988 944 Turbo S Silver Rose Metallic, K27/6, Vitesse MAF, Tial 38mm DP WG
Semper Fi
Old 03-30-2012, 11:10 AM
Guest1287's Avatar
The one that goes in the box.
Old 03-30-2012, 02:51 PM
944 addict
mytrplseven's Avatar
Send a message via AIM to mytrplseven
measure the two filters. If there's no difference, perhaps you're installing it upside down or it's just a little tight. If it's that, I'd put a little oil on the inside of the air box and see if it'll slide.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman.
Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved.
Old 03-30-2012, 03:37 PM
In the Fires of Hell.....
kdjones2000's Avatar
I have to fit mine into the top of the air box first, then put those into the car. That way the gasket slips into the airbox properly. If you try to put it in the bottom first it can be difficult to get it to seat properly all of the way around.
I never had a problem with closing my hood because of this, but you never know...
Good luck, Keith
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 03-30-2012, 04:22 PM
