AFM #725
Gawernator's Avatar
Question A Few Questions
When driving with the window down sometimes I feel like I can smell gasoline, is the engine running too rich or could I be leaking fuel? I don't see any spills where I park. What should oil pressure be (Moderate California weather) at start-up? After five minutes? I'm preparing to replace the coolant in the system and replace the transmission oil, anything I should be looking out for? The manual says 80 SAE oil but I was able to get Mobil 1 75-90W after seeing some forum users here use it... should that be okay?
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio
http://www.gawerracing.com
Old 04-18-2012, 04:25 PM
Your hatch seal is bad.
75w-90 will work just fine.
Old 04-18-2012, 04:30 PM
AFM #725
Gawernator's Avatar
Hatch seal is bad?
Originally Posted by Gawernator View Post
Hatch seal is bad?
Yeah, they shrink and create a gap in the back center where when you open your sunroof or window it pulls exhaust into the cabin because of the aerodynamics of the car.
I had that problem and when I replaced the inner shift boot (the rubber one) it got a lot better so I never fixed the hatch seal.
Old 04-18-2012, 05:02 PM
AFM #725
Gawernator's Avatar
Oh okay, well the hatch seal I see here on pelican is over $100, so I can hold off on that for a while.
Old 04-18-2012, 05:11 PM
AFM #725
Gawernator's Avatar
Apparently I need a GL-4 oil and not GL-5 like Mobil 1, apparently the contents of the newer style oil will ruin the transmission?
Old 04-18-2012, 05:53 PM
