curtisr
curtisr's Avatar
Can I Use This Thermo Switch???
I ordered a thermo switch for my '87 924s and what came was a three tabbed/pronged (?) switch rather than the two tabbed/pronged model I expected.
To return it would be a considerable hassle as it involves sending it from Canada to the US. So, my question is: can I use it?
Beck/Arnley 201-1266 Engine Cooling Fan Switch
Old 04-24-2012, 06:01 PM
ernie9944's Avatar
[QUOTE=curtisr;6709455]I ordered a thermo switch for my '87 924s and what came was a three tabbed/pronged (?) switch rather than the two tabbed/pronged model I expected.
That thermo switch is for late 944/S/S2/951/968 not 100% sure but I think you will need the 2 pronges same as the early 944 on your 924S.Try to get one from those guy Auto Parts, Auto Part - Buy Auto Parts Online since they are here in Canada.Once on site look under (lightning,body & electrical) parts # 36520.GL
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
Old 04-24-2012, 06:30 PM
ernie9944's Avatar
OOP!! part # is OEA 1635975
Old 04-24-2012, 06:45 PM
Custom User Title
mikepellegrini's Avatar
The two prong and three prong aren't interchangable.
Plus you need to pair the thermofan switch to your thermostat - so they're in the same temperature range. I forget what the formula is.
If you have the wrong thermofan switch and an 80C (stock) thermostat, the fan may never shut off.
Maybe John AZ or someone will chime in with the correct pairing information?
83 944 NA - Black on black
86 951 - Red - SOLD 7/21
16 Ford Expedition
He who hesitates is lost.
Old 04-24-2012, 07:34 PM
curtisr
curtisr's Avatar
Thank you! Will order today.
Old 04-25-2012, 03:11 AM
curtisr
curtisr's Avatar
I did NOT know that! Thank you!
Old 04-25-2012, 03:13 AM
9FF 9FF is offline
9FF's Avatar
Low temp thermostat 71deg matches 75deg fan switch.
OEM temp thermostat 80deg matches 85deg fan switch.
High temp thermostat 87deg matches 92deg fan switch.
Old 04-25-2012, 04:39 AM
mhr mhr is offline
Hey Curtisr thought you may be interested in this. You are close to Kingston right?
I went last year it was fun. If the forecast is good I will go again this year.
http://forums.rennlist.com/rennforums/showthread.php?t=691952&referrerid=76285
Old 04-25-2012, 06:29 AM
curtisr
curtisr's Avatar
2012 Kingston, Ontario 944 meet - Rennlist Discussion Forums
Yes, we're 10 minutes north of Kingston. I indicated a desire to join in; however, not having my 924 up and running I asked if I could make an appearance in the other Porsche I have. As well, I left a query as to whether it's for petrol-heads or couples, or what...
Old 04-25-2012, 04:56 PM
curtisr
curtisr's Avatar
Thanks, I will save this for future reference.
Old 04-25-2012, 04:57 PM
smokin_944's Avatar
Wahler thermal fan switches have numbers.
823.959.481 is 75/70*
823.959.481 D is 82/77*
823.959.481 F is 92/87* and
823.959.481 E is 65/60*. Honestly there isn't much of a use for the 65/60* as the fans run a long time. Just my .02 cents.
1984 - 944 Black / Wilwood/Brembo brakes / fresh M-474 suspension / Welt 250 lb fronts / 28 mm solid T-bars / M030 bars w Racer's Edge hardware/MSDS headers
Old 04-26-2012, 05:48 AM
mhr mhr is offline
oh didn't realize was same person. So I look forward to seeing you. Bring whatever and whoever you want. There was a 928 last year and someone also came with da wife.
Old 04-26-2012, 12:31 PM
