mk3tg's Avatar
Passenger side clickuing and weird noises
hey guys my 944 has had an issue for the last month now I've narrowed it out to two things the wheel bearing because the wheel did wobble alittle when i put it on a lift and moved it back and forth and maybe the cv joint or axle? the boot doesn't looked ripped but still, the noise get worse and worse every time i hit a bump ideas? also when somebody sits in the passenger seat and i hit a bump the cars fine no noise or anything
NOTE: new issue in the front passenger whenever i turn or hit a bump i get a nice clunking and craking noise what can it be
Audi TT Project 1.8t Stage 3 APR 340WHP
Porsche 944 2.5slow restore
Vortex account
http://forums.vwvortex.com/member.php?434214-Mk3TG
Old 04-26-2012, 09:56 AM
944 addict
mytrplseven's Avatar
Send a message via AIM to mytrplseven
what year 944? You may be right on about the wheel bearing and or the carrier. It's possible you might have a bad shock on that side as well. They're easy to replace but I'd pull the wheel and test the hub for side to side and in and out play. Clarks garage has an item on this hub issue.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman.
Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved.
Old 04-26-2012, 02:29 PM
TibetanT's Avatar
Check that the passenger seat is bolted to the floor properly, since the car makes no noice when someone is sitting there.
Just a thought.
Ed Paquette
1983 911SC
1987 944S
1987 944 Manual (Donated to the Nat. Kidney Foundation)
1987 944 Automatic (Recently sold to another Pelican)
Old 04-26-2012, 10:20 PM
mk3tg's Avatar
the seats bolted i jacked up the car and i bent the fender at the bottom :facepalm: but the wheel was wobbling back and forth pretty bad the struts didnt look frozen and all the other components look new
Vortex account
Old 05-02-2012, 07:00 AM
9FF 9FF is offline
9FF's Avatar
Little front wheel wobble = bearings.
Big front wheel wobble = a-arm ball joints.
Old 05-02-2012, 08:37 AM
968 GUY's Avatar
mk3tg...front or rear? Just to clarify.
One post mentioned cv joints, another mentioned struts.
87 951 all stock exc. cup II's /94 968 6-spd, lowered,17in. RUF Speedlines, M030 anti- sways/ 94 968 Tip, Cup II's, otherwise stock
Old 05-02-2012, 01:52 PM
mk3tg's Avatar
front passenger i'm lookimg at everything
Vortex account
Old 05-02-2012, 03:18 PM
mk3tg's Avatar
Vortex account
Old 07-20-2012, 10:11 PM
944 addict
open the hood, stand or push on the front bumper up and down and look at the top of the shock towers. If they're moving around, the strut mount is probably shot and It's time to replace the whole package, i.e., strut, mount and then realign. If you're wheel's wobbling, I'd suspect the control arm ball joints. Could be you have 2 problems and not just one.
Old 07-21-2012, 06:22 PM
