Hellraiser's Avatar
Send a message via MSN to Hellraiser
Cruise control 944 type2 only accelerates
Hi,
I recently bought an '86 US Porsche 944 (type2)
and found out that the cruise control doesn't engage,
but the car does accelerate if you keep pushing the lever towards the dash.
Can there be a simple reason why it doesn't engage?
Thanks!
Kind regards,
Johan
Old 05-16-2012, 04:07 AM
Bad brain... very common problem...
Good luck, George Beuselinck
Old 05-16-2012, 04:52 AM
Hellraiser's Avatar
Ok, thanks, tought it could be a bad switch on the brake/clutch pedal.
Old 05-16-2012, 05:08 AM
Proprietoristicly Refined
John_AZ's Avatar
You could do a few of the possible repairs found on Clarks-Garage.
Cruise Control - General Information and Repair
Also read the car owners manual for operation detail.
GL
John
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 05-16-2012, 05:48 AM
944 addict
mytrplseven's Avatar
Send a message via AIM to mytrplseven
Mine does that when I hold it down, too, but then disengages when I lift off the switch. If I engage it normally and don't hold it down to accelerate, it works ok but won't hold the speed in the 72 to 80 mph range (the range where I typically drive). It slows down instead to 72. Go figure. something to troubleshoot after I put the belts and one leaky seal back on and reseal the hatch. Busy, busy, busy.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman.
Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved.
Old 05-16-2012, 07:29 AM
mine has the same issue. it worked before at low speed and now it's failed completely. i sprayed contact cleaner on the controller and the servo connectors but that didn't do anything. i may need to take the servo apart to do some cleaning.
cruise on these cars are basically useless though. it's not like i'd drive this car for long road trips.
Old 05-16-2012, 11:02 AM
