Hatch Wiper Delete DIY for $5
My 87 Turbo didn't come with a rear wiper, just the hole for the motor. I read several threads about DIY delete kit and decided to go to Home Depot to see what I could come up with. Here's the end result. Please excuse the plastic tape around the hole, I put it there to avoid any scratches to the glass. This was just the first attempt. Later I will do this with black screws and two rubber washers cut to proper size.
Here's the parts list from Home Depot:
Surface Grip 25mm Anti Skid Pads (#9644) - you need only one - $2.49
Neoperene Washer 1x$ - 1-1/4 - need two - $0.76 each
#10-32 x 1/2" Flat Head Machine Screws and Nut - need one - $1.18. Change this to 3/4" if using two washers
There you have it. It doesn't look too pretty but doesn't look awful either. Also much lighter weight than a 17mm hex bolt not that it would matter much. You also have parts left over for 3 more delete kits. Just buy the washers.
I will upload new pictures when I redo the job a bit more properly. If you're more paranoid about water dripping in, just use some silicone between the washers. That would do it. I thought it unreasonable to pay close to $20 for a pretty anodized aluminum delete "kit".
Old 08-19-2012, 07:48 PM
I pretty much did the same thing, only i used a carriage bolt insted, then i painted everything flat black and put it together. It looks great on the outside, you cant even really tell the difference between an oem plug unless your looking for it!!!
Old 08-23-2012, 09:02 AM
RM512's Avatar
Same here except I used stainless steel hardware and a ny-lock nut.
Old 08-23-2012, 11:34 AM
Sorry to revice such an old post ... but anyone know the part # for the original rear wiper delete. Looked at 968 and 944 PET and not able to see it anywhere. Thanks Paul
Old 03-23-2014, 01:07 PM
Let me google that for you
1981 924 Turbo
1987 N/A Auto
Black w/Can-Can Red Interior
Old 03-23-2014, 01:14 PM
Originally Posted by jeffrsmith View Post
I've googled until I'm cross eyed! .. and I can't see the part number. If you are a better googler than me perhaps you can help
I wouldn't post without googling first!
Great link by the way ... got to love a smart arse!
Old 03-23-2014, 04:46 PM
Com'on jeffrsmith ... you are the king of google ... show me the light!
Old 03-23-2014, 10:40 PM
477845333 plug
477955439 gasket x2
477845331 washer
N01111814 nut
Old 03-24-2014, 12:49 AM
Thanks jrboulder
beamishnz - those parts are available at Jim Ellis Porsche Parts and are not cheap.
rear lid rear spoiler. Fits: Porsche | Jim Ellis Porsche Parts
1981 924 Turbo
1987 N/A Auto
Old 03-24-2014, 02:46 AM
I have one or two of the wiper delete plugs spare if you want one, $25 shipped each. PM me if interested
Old 03-24-2014, 08:30 AM
Thanks guys for that ... yep stock parts for the plug are pricey! About to pm v2roaket
Old 03-24-2014, 02:24 PM
Thanks v2rocket ... funds sent. Really appreciate you helping me out. Regards Paul
Old 03-26-2014, 09:13 PM
