I found problem with The Hinge on the Hatch
Today, I was trying to fix the drain tubes and I noticed that one of the pins holding the hatch on the hinge was coming out. Also, I noticed that the Glass itself is coming undone from the frame in some spots. Thus, I have a couple of questions.
A. Is this a common problem with 944's?
B. How do you replace the hinge if it brakes?
C. How do you fix the Glass separation?
Please see the pictures I have on this.
http://i1190.photobucket.com/albums/z456/Crazyone3/944%20Porsche%20Related/944%20need%20help/6_zpsca5b7f1f.jpg
http://i1190.photobucket.com/albums/z456/Crazyone3/944%20Porsche%20Related/944%20need%20help/10_zps534a5498.jpg
Old 10-07-2012, 08:46 PM
Volhv's Avatar
Mine almost came out.
Check your hatch hinge pins!
1986 944 NA Sapphire Metallic
http://944porsche.blogspot.ca/
Old 10-08-2012, 01:23 AM
AFM #725
Gawernator's Avatar
For the glass separation, if it's not very bad you're probably best off with a easy fix on injecting some RTV silicone in the gap to seal out air/noise/water, since it's a big pain to reseal it, and lots of guys end up breaking the glass.
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio
http://www.gawerracing.com
Old 10-08-2012, 01:41 AM
968 GUY's Avatar
Do a search for hatch glass separation. Lots of people have the problem with glass separating from the frame.
I had one of mine done at a glass repair shop. It really looks good now. I need to do another one, may try it myself.
87 951 all stock exc. cup II's /94 968 6-spd, lowered,17in. RUF Speedlines, M030 anti- sways/ 94 968 Tip, Cup II's, otherwise stock
Old 10-08-2012, 07:42 AM
944 addict
mytrplseven's Avatar
Send a message via AIM to mytrplseven
Getting ready to pull the hatch for resealing the glass to the frame. I'll check the pins when I do. Good heads-up info nonetheless.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman.
Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved.
Old 10-09-2012, 09:12 AM
Took the Hatch off
Ok, Today I took the Hatch off so I can fix the hinge problem. I can't believe that I was driving the car with the Hinge like this. It could have flown off on me and hit someone.
I do have a question. While I have the hatch off, How does the Frame come off. I want to fix the detachment of the glass while I am it. Is is glued, Can I buy a new Frame for it?
Old 10-14-2012, 05:48 PM
