dumb oxygen sensor questions
if I use penetrating oil on the O2 sensor when removing it, how should I rinse the residual oil out of the threads on the exhaust pipe?
on a Bosch 13011, what is the signal wire in the plug end?
will a torque wrench and O2 sensor socket work in that area, crowsfoot, or anything else?
Old 12-01-2012, 11:58 AM
AFM #725
Gawernator's Avatar
I sprayed some PB blaster. Used an adjustable size wrench and it screwed off really easily, first try. Luckily. Then carefully inserted the new universal sensor. Tightened to snug.
Old 12-01-2012, 12:04 PM
Proprietoristicly Refined
John_AZ's Avatar
The 2 white wires are the heater wires---the black is the signal wire.
On the O2 sensor cord---at the connector plug end--the single "male" pin is the signal.
John
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 12-01-2012, 03:33 PM
