dumb oxygen sensor questions
if I use penetrating oil on the O2 sensor when removing it, how should I rinse the residual oil out of the threads on the exhaust pipe?
on a Bosch 13011, what is the signal wire in the plug end? will a torque wrench and O2 sensor socket work in that area, crowsfoot, or anything else? |
AFM #725
I sprayed some PB blaster. Used an adjustable size wrench and it screwed off really easily, first try. Luckily. Then carefully inserted the new universal sensor. Tightened to snug.
Proprietoristicly Refined
The 2 white wires are the heater wires---the black is the signal wire.
On the O2 sensor cord---at the connector plug end--the single "male" pin is the signal. John
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo) |
