Motor Head
Power Windows not working
I did some troubleshooting tonight and found no power to the fuse block for the power windows. Should there be power there with ignition on or is the fuse only powered when the relay is activated? No click at the relay, no voltage drop at all when any of the switches depressed, no power at the switches. At first I was ready to go after the grounds, but without power the grounds don't matter a bit.
2013 Ford Focus SE - 5spd mtx, Spectre filter, Unleashed E85 Tune, much more to come. - DD
2011 Ford Flex - Catless Downpipes, lightweight Mustang Motorsport 20x8.5 wheels, 3 bar MAP, Unleashed 15 psi tune - SOLD
1986 944 Turbo - 100K mile cream puff - FOR SALE
Old 11-08-2012, 04:42 PM
Proprietoristicly Refined
John_AZ's Avatar
Give the window trouble shooting tips from Clarks a try.
Electric Window Troubleshooting
If you get down to taking off the door panels to inspect the motors, look at the window regulator rollers. Rennbay has a kit to replace.
Porsche 944 window regulator plastic rollers kit
GL
John
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 11-09-2012, 03:15 PM
