Rear spoiler delete??
Ok, so I have been toying with the notion of deleting my spoiler. My question is...Is there a kit for this or how would i fabricate the seal to replace the wing? Also if anyone has pics of a hatch without a wing that will help also.
P.S I don't care if you dont like the look. This is hypothetical
1988 Satin Black Metalic , Plaid interior 944 "Celebration Edition" Sold and now autocrossed in canada 1985.5 Guards Red 944na 66,000 miles (SOLD in 2002 )http://porsche944celebrationedition.weebly.com/ |
Spoiler delete
It would be easy to do a spoiler delete by finding an early 924 that was delivered from the factory with no spoiler. Remove the hinge bolts , swap hatches and you are done.
Warning - I play with Porsche's ![]() 1970 -914 / 1982 -911 1984 -928 / 1987 -928 |
![]() This is a shot of the rear of my 79 - 924 with no spoiler.
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
I have pictures on my other laptop of my 944 with no spoiler... doesn't look too bad really.... The spoiler isnt the seal so you are fine there.... You'd just want something to cover the bolt holes with is all....
AFTER BEFORE
i don't know what the implications would be for removing the spoiler?
maybe less aerodynamic, less economical, maybe a bit light in the rear at speed? ![]() the early 924 didn't have one, it was pretty clean and just a simple wedge. my '78 didn't have one and it felt rock steady at an indicated 200kph (probably 188-190kph actual!) The 944, with a wider body and bigger tyres achieved its low CD with the aid of the rear spoiler. i know my friend spun his series 2 RX7 (gen 1 for you guys?) taking a corner at the same speed he normally did, except this time he had no rear spoiler... he was doing 150 kph though!
https://www.instagram.com/kiwi944s3/ '86 944S3 conversion - '94 968 3.0 engine - 6 spd/LSD - 17x8,17x9 Oz Racing Crono wheels Last edited by J1NX3D; 02-08-2010 at 12:37 AM.. |
rear spoiler delete
Hello all,
I recently purchased a 1983 944...it's a great looking and running car, but i truly despise the rear spoiler. Is there a way of removing it??? Also, is there something of a kit and or solution to cover up the bolt holes?
White and Nerdy
Why do you despite it? Porsche specs shows it makes quite the difference in drag, and it helps neutralize rear lift. Aerodynamicly, the basic shape of the car, tries to lift the rear wheels off the ground, this lifting force, takes energy. The spoiler cuts the lifting force, reducing drag. I'm not sure on aero specs of the 944 without a spoiler, but I do on the 924/924 Turbo, the Turbo had a big drop in drag from the rear hatch spoiler.
Shadilay. |
Non Compos Mentis
By far the easiest and cheapest thing is to simply replace your rear hatch with one from a 924.
Sell your 944 hatch, and the swap is free. |
Non Compos Mentis
Aerodynamics won't matter much if the car never sees the track. For an around-town daily driver, no factor.
Stability may start to suffer above 70-80 mph, and I wouldn't want to take a spoiler-free 944 very far into tripple digit speeds. |
1983 944 N/A
I went with the small wing from a early 924, I think it looks cleaner and easier to get into the rear hatch on the 83
