assembly lube preference
as the title suggests, what is the general consensus on preference.
A good start would be what is listed in the WSM. I don't have mine right now. Do a search on this and other forums, i'm sure there is plenty of opinions.....kind of like the best oil argument.
87 951 all stock exc. cup II's /94 968 6-spd, lowered,17in. RUF Speedlines, M030 anti- sways/ 94 968 Tip, Cup II's, otherwise stock |
![]() ![]() Follow your owner shop manual .
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
Assembly lube...
I used to use Lubriplate. |
Redline Racer
I used the Sta Lube and it worked fine.
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky |
I haven't needed to assemble anything in the 944 requiring assemkbly lube. That said I have used Sta Lube in several other engines. It's recommended by many engine builders.
Clifton |
Sta-Lube is not at all bad stuff, but I am using Redline these days...
![]() ![]() They also have a more liquid version I've been happy with too, looks like raspberry syrup...
Vaughan Scott http://www.vaughanscott.com http://www.924.org |
thanks, picked up some Sta-Lube, that is all they had. wish me luck!!
some guys like assembly lube - others stay clear of it on purpose and only use break in engine oil.
i always used isky lube. |
