jtdig64's Avatar
front crest...need help
I need to change the front porsche crest on my 84??? Does anyone have some simple notes to do this..
Thanks,
Todd
77 911s
84 944
99 z3 (wifes car)
GMC service van
Old 06-24-2002, 01:34 PM
AFJuvat's Avatar
The crest is held in by two "speed nuts".
If you can reach it, raise the headlights, and snake your arm through the opening and unscrew the nuts - at this point the crest pops right off.
reverse the procedure to install the new one.
My hands/arms are too big, I had my 10 year old do it. (you can probably bribe a neighbor kid to do it for you)
Optionally, you can remove the nose panel and install it - but that is a big PITA in my opinion
AFJuvat
Old 06-24-2002, 10:30 PM
I have an 86-951 and my crest did not have nuts. It was a pressure type fitting. I have used a putty knife (very careful) and/or removing the nose panel. (2-bolts, 4-Nuts, 6-screws) but when taking it off it might be wise to tape off your bumber. The bat wings tend to scratch a little when pulling it out.
Old 06-26-2002, 05:28 AM
