A/C Flow Problem
Can someone give me some ideas as to what is wrong with my AC system? My controls all work fine, the heater works and I am able to get outside air. But as soon as I turn on the AC switch the normal fan stops, the compressor starts up but I get no air out of my vents. From the amount of sound I am assuming that the AC works but just isn't getting through to the vents. I can also hear the AC relay in the passenger foot well working when i first turn the switch. Any ideas? 1984 944 N/A.
1984 Porsche 944 N/A
1978 Porsche 924 (Sold)
Cheers,
Mitch
Old 01-09-2013, 06:50 PM
I have also looked on clarks garage and other websites and found next to zero info on this issue
Cheers,
Mitch
Old 01-09-2013, 06:51 PM
Proprietoristicly Refined
John_AZ's Avatar
I am thinking you need the AC for defrosting?
Check all the relays-fan & AC & ??? to make sure they are connected and not corroded/fouled.
Pelican Parts: 944 Early Fuse and Relay Layout
Try the common vent parts/heater clips that fail:
14. Porsche 944 Climate Control FAQ
I cannot guess if your assumption of "the AC works" is accurate.
Have you had the AC checked in a shop or your own HIGH/LOW pressure guages?
EDIT: I just found this thread that may help:
1984 fan resistor location
GL
J_AZ
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 01-09-2013, 08:17 PM
ASE Master
alfadoc's Avatar
It's an early car John, so no heater clip problem.
1989 944S2 (sold after 11 great years)
1980 911SC Weissach (bucket list car)
1975 914 1.8 (future restoration)
1993 968 Coupe 6 speed (new acquisition)
Old 01-10-2013, 06:02 AM
John_AZ's Avatar
Thanks alfadoc
Old 01-10-2013, 07:21 AM
The only reason I would like to have it working is that it gets really hot in the car without tinted windows and sitting in rush hour traffic int he summer and for added resale value.
I have pulled the two relays under the passenger vent out and they look fine (was some glue stuff rattling around inside). I have also replaced the fan relay in the main fuse box recently.
I'm thinking it may be some sort of vacuum leak as the main flap to allow air from the AC is operated by a vacuum and it is not working(Part A in picture). Part B makes a sound when you move Part A by hand that sounds like pumping a hand bike pump. Sorry for the lack of proper terminology, I have tried to avoid the HVAC system due to my very limited understanding of its operation.
Cheers,
Mitch
Old 01-10-2013, 10:04 AM
AFM #725
Gawernator's Avatar
I swear there is a plague of members here having strange HVAC issues
Old 01-10-2013, 10:34 AM
John_AZ's Avatar
You could pull the entire heater and replace the foam and check for operation---a lot of work.
SolReaver did a DIY. The 924S series has the early 944 heater/AC unit. A lot of pictures that may help.
87 924S heater core
A lot of work!
J_AZ
Old 01-10-2013, 11:02 AM
Tags
airflow , no air , vents
