fty fty is offline
fty's Avatar
Send a message via AIM to fty
Anyone install a msd blaster 2 with no ballast?
Anyone install a blaster 2 with no ballast in a stock system.....? I also need to know that there was no ignition system installed with that too....thansk-chris
82' 911 SC"Go Go Green" 87'3.2L,Turbo Brakes,Brake Bias Valve,Fiberglass Front Clip, 16" BBS, Multiple Strut Braces, Re-valved Bilstiens and a few more "Stock" additions. SOLD
04' Audi A4 Avant Quattro S-line- RS6 look alike with half the HP
http://www.eurocompulsion.net
Old 06-29-2002, 07:28 AM
I've never installed one, but knowing what i do about electrical current, it's likely that you'll burn out your DME. The ballast resistor is there to bring the coil resistance back up to stock level. as the coil resistance goes down, current through the coil goes up, this is current that the DME has to control. there is a definite limit to the amount of current the DME can handle before you burn out your coil driver (the part inside the DME that actually turns the coil on and off)
Bottom line: you could try it, but it's like playing with fire. you might be fine, you might get burned. unless you have a spare DME laying around, i'd use the ballast resistor.
Old 06-29-2002, 09:29 AM
fty fty is offline
fty's Avatar
yeah i put in that ballast ressistor...msd coil works good. thanks..-chris
Old 06-30-2002, 04:27 PM
