how to remove clutch housing?help?
I need good tip how to remove clutch housing retaining bolts 2 at the top of the housing- 2 at the bottom. 3 of them are very easy but i'm stack with the 1 on the left side above a slave cyl. --19mm-- I,m going to buy tomorrow 3/8 extension the longest i can get and bend like banana i hope this is going to do a trick. If anybody have some idea please post the answer what is the best way to tackle this problem> PORSCHE 944 -1985 EARLY THXS. LES
Custom User Title
You did remove the slave and move back the torque tube first, right? http://www.clarks-garage.com/shop-manual/clutch-01.htm
The top left torque tube bolt I do with a couple long extensions and a wobblie. The top left bellhousing bolt (IIRC) you have to lower the engine to get to - you have the engine supported by a jack? Just lower it a bit and then the bolt is easy to get.
83 944 NA - Black on black 86 951 - Red - SOLD 7/21 16 Ford Expedition He who hesitates is lost. |
White and Nerdy
I use a bendable socket, and several feet worth of extension. I'm sitting in about the middle and right of the car, with the extensions crossing over the top of the torque tube to the left. Porsche replaced the 19mm head bolts with 17mm to give it more clearance. It can help to have a force pushing up on the front of the engine to tilt the back down, and give you more room. This will also make removing the bellhousing a breeze with that little bit of extra room.
Shadilay. |
I actually took the passanger side motor mount off when I did my clutch job a few months ago. I forget the reason why (could be so I was able to get the bell housing off, btu really forget), but made it easier to get to the upper 2 bellhousing bolts. Yes, I did have some support under the engine with the mount off. If your doing a clutch job,
bread to get the flywheel bearing out worked great for me. Pilot bearing removal- BREAD
Steve- If you havent looked, look- www.clarks-garage.com 87 951 red- Maria (current) 84 944 white- Percilla (current DD) 85.5 944 red- Pinta (past) 87 924S red- Nina (past) Last edited by thekidd; 01-21-2013 at 11:25 PM.. |
Proprietoristicly Refined
Universal Metric socket and a couple of extensions.
![]() Have you removed the reference sensors yet? Must come out to remove bell housing. GL J_AZ
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo) |
John where did you buy that 17mm flex socket? A friend lent me a Teng one to undo the torque tube bolts, then I returned it. When re-installing the engine I tried very hard to buy one(or even a set) without success-I ended up using every extension that I had and needed a second pair of handes to hold the contraption steady as I torqued the bolt up.. I will be in Florida in June and intend to try to get this very useful type of socket there.
1986 924S bought new. Now used for AutoX and street. Chipped, throttle cam, highflow filter in original airbox/snorkel, 14mm rear sway Hyundai Ioniq hybrid daily driver Vindicator Vulcan V8 spyder, street legal sports racing car (300hp,1400 lbs kerb weight) used for sprints on circuits, and hillclimbs |
Many places, probably Sears Craftsman is an easy choice to buy in FL.
![]() I see them on eBay as well. Get the correct size or maybe a set. J_AZ
I bought a set of ratcheting obstruction wrenches just for these bolts...
Something like this... https://ebuy.craig-international.com/cat/776/32519/
Good luck, George Beuselinck |
Thanks guys for the sourcing information
