Porsche Crest Keys & Locks
Have a late 944 restoration ongoing... I found the drivers side door is loose when I use the key, but if I slightly angle the key I can get it to open. 25+ years takes a lot of a lock, cylinder and the mechanics. I believe I can move the passenger side to the drivers and do a clean swap. But I am still only buying some time before the good one goes. Usually happening at the worst time. I searched and have found little on the subject. Does any GPO have a few small hints/ideas to assist in this? I doubt I am the only one facing this problem.
I would really like to keep the keys and refurbish the cylinders. A new lock set is somewhat out of my price range.
Danke!!!
Old 02-04-2013, 10:57 AM
Frankly my dear....
rhett's Avatar
Hi Porsche37, being in Europe you are a lot closer than most Forum members!
Anyway, yes you can do a straight swap of the worn drivers side lock across to the passenger side, You can also re-build a lock cylinder if you are really careful to remove the tumbler slides from an unworn cylinder and replace them (in order) with the tumbler slide set from your lock. You can usually get a late passenger side that would do the job from a porsche breaker. That way you can keep your original keys. I would then recommend fitting a remote control central locking unit. I have done this and it works a treat. You dont have to use the key in the lock then, and that saves wear and tear!
Porsche - accept no substitute
Blue 1999 Boxster - Brief encounter! Black 1988 944S - Ongoing project
Black 1987 944S - Gone but not forgotten
Metallic Black 1980 924 - Those were the days....
Red 1979 924 - Hmm Minerva blue 1979 924 - Where it all began!
Old 02-04-2013, 12:29 PM
VOTS89's Avatar
A locksmith can rebuild your cylinders to match the existing key but then your locks will be new and the old keys might not want to work.
I had my ignition, both doors and the hatch rekeyed for $100, I bought two new porsche keys and had those cut by the same locksmith to match the rebuilt cylinders.
Some jobs are best left to the experts, I think this is one of them.
I recommend you replace any plastic linkage in the doors if you pull the locks out.
Bruce
Old 02-04-2013, 03:15 PM
AFM #725
Gawernator's Avatar
Bruce
+1 that's a good price
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio
http://www.gawerracing.com
Old 02-04-2013, 03:19 PM
Great thoughts, thanks for the response. I will check if there is a good locksmith that can get this done. I already learned some lessons recovering the dash... Yes Bruce, some jobs are left to the experts!
Old 02-06-2013, 08:45 AM
