Whats the average life span of motor mounts on a non tracked car? I have PO receipts of my motor mounts being replaced mid 2009. I definitely get the massage chair feel at 950 RPM and goes away when hit 1100 RPM.
A flat head screwdriver will fix that
Old 02-26-2013, 11:50 PM
AFM #725
Gawernator's Avatar
He means turn it up to like 1,000
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio
http://www.gawerracing.com
Old 02-27-2013, 12:22 AM
dsmithwc04's Avatar
I checked the two grounds under drivers side dash. Both were tight with no corrosion. So that's one down on the tach.
I also checked the "y" tube mentioned a couple posts ago and it looked good and secured as well as everything around it. Will the method mentioned with a youtube link work the same on an NA as the turbo. The video had a turbo in it and I wasn't sure if the vacuum was similar or not.
'82 911 SC track car - SOLD
'86 944 NA - SOLD
'01 Boxster S
Old 02-27-2013, 05:49 AM
porscha
matty89's Avatar
Did u check ur J boots from the Air filter to the AF. M meter? For cracks? Rubber drys with old cars
Old 02-27-2013, 08:53 AM
