-   -   Can someone explain this (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/736422-can-someone-explain.html)
Gawernator 02-27-2013 06:55 PM
I still need to watch Office Space LOL
Chunkerz 02-27-2013 07:15 PM
Originally Posted by mattdavis11 (Post 7299940)
What light? I'll wind mine out to 6K everyday I drive it.
The up shift light. It comes on around 2500ish RPM to say, "hey shift now and save gas!" and again at like 6000ish RPM to say, "WTF are you doing?!?! SHIFT YOU MORON!!!! Your engine is about to grenade!!!"
Yes you do. Make sure you watch the real version and not the censored TV version.
Gawernator 02-27-2013 07:16 PM
When you drive with a light foot and go conservatively and slower it comes on around 2,100-2,300 lol
FrenchToast 02-27-2013 08:07 PM
Originally Posted by VirginiaF1 (Post 7300243)
not wanting to throw #2 rod.
To do any damage (from what I understand), you really need to run into oil starvation issues. And that only arises from prolonged time on the track, i.e. multiple hours where the car is above 4k RPM all the time.
Most of the LeMons entrants who run 944's run into oil starvation only after several hours. Some go the whole way.
It would probably be impossible to run into this issue on the street. Unless you drove everywhere at redline in first gear.
It doesn't come on at 2.5 and 6, what it is actually doing is changing the shiftpoint based on how you are driving. It only came on the series II NA cars. (Unsure about the 924S, 16V and 968) It's called CASIS (Computer something Shift Indicator System or something like that) and runs through the ECU. It varies your ideal shift point based on throttle position and other things. Pretty interesting, actually.
It might be something that runs like a computer for an automatic transmission, but rather than doing any shifting it just shows a light.
Take care!
Gawernator 02-27-2013 09:13 PM
So, I'm not using much throttle now am I ;)
mikepellegrini 02-27-2013 09:23 PM
What's all this 5th gear stuff? I've never had my 951 out of 3rd (hardly). I shift into 4th at 105 MPH. Only one time, I got on it in 4th - I was racing a VW GTI - and buried him as soon as I hit 100. By the time I was at 115 MPH, he'd dropped way back, so I got off it. I've never had the balls to go all the way to 5th.
I have to admit I was surprised, because at 115 MPH, at about 3,000 RPM in 4th, the car was pulling like all get out and subjectively, it didn't feel any different than say 60 MPH. I was really impressed.
My NA, I love to play with, too. There's a tight, 180º turn at work, and I love sliding around it at about 30 MPH, tached out to about 6,500 RPM in first ( I come into the corner at about 40-50 MPH in 2nd and downshift as I start the turn).
These cars are made to be driven. If I break something, I'll fix it.
What fun is it driving a Porsche, if you treat it like a Studebaker?
Jeeze!
Gawernator 02-27-2013 09:55 PM
I'm not at that engine pulling level yet, lol I'm just trying to rebuild my injectors and not have them leak.
Gawernator 02-27-2013 11:25 PM
I also like how not a soul answered my question but this became a flame thread on shift points lol.....
flash968 02-28-2013 06:16 AM
the simple answer is: crap in your injectors.
this is not a job to be done at home. even at the pro shops, sometimes it takes cleaning them twice. i just had to do that with a set. i sent them to one place (not my usual one) and they did not get fully cleaned, so the flow rate was off. they went out to my usual service place, and now they are perfect again.
ditch68 02-28-2013 06:38 AM
Jeeze!
What he said! I have mine to redline frequently, hell, the turbo isnt fully spooled until just under 4k!
I do cruise in 5th on the freeway at 80-82ish (speed limit 75) just to save gas if I drive it to work.
But sheesh,I flog that thing. Every onramp is a full blast like out of corner 5 at Road America! I heel toe and drive it like it was meant to be.
Really, why have one of these if you dont use ot like it was built to be used? Yes, IT WAS BUILT FOR THAT! These cars will amaze you at the limits of their potential, have fun with it!
Safely, of course, but you get the idea.
Jeff
ditch68 02-28-2013 06:44 AM
Sorry LOL. It was necessary, though...:)
Toast, my '88 924S had CASIS.
Jeff
p-talk 02-28-2013 07:56 AM
You mention that it ran fine the second time you started it up. And that you used some carb cleaner and silicone spray. Possible that some residual chemicals needed to be burned off. Drive it more and see if the behavior continues.
mueller944s2 02-28-2013 08:33 AM
Jeeze!
Maybe I'm reading this wrong, but 115 at 3k in 4th? And what gear do you cruise on the interstate in?
Chunkerz 02-28-2013 08:53 AM
Take care!
Interesting. It's always come on at those exact RPMs for me, no matter how I'm driving.
mikepellegrini 02-28-2013 09:12 AM
<!-- BEGIN TEMPLATE: bbcode_quote -->Maybe I'm reading this wrong, but 115 at 3k in 4th? And what gear do you cruise on the interstate in?
I believe that's right. About 3k at 115. The car was just coming into the power band.
Sure I do use 5th on the freeway, cruising along at 70. But that's about it. If I'm driving local, it hardly ever gets out of 4th.
mueller944s2 02-28-2013 09:14 AM
Take care!
I think they got rid of it for the S2, mine doesn't have it.
mueller944s2 02-28-2013 09:19 AM
It should be at least 5k for a stock tranny, has yours been modified?
Gawernator 02-28-2013 10:15 AM
Hate to rain on the parade but I think my injector #1 is FUBAR? I re sealed and after a couple re seats it stopped leaking. Now it's leaking again and maybe worse. From the hole where it goes into the manifold. I used pure silicone to lube the o rings and nothing looks torn. No leaks from the rail or other injectors. I'm starting to think from what I've read that it's leaking at that joint where the tip meets the body? Amazed my car isn't on fire yet and I'm gonna pass out from all this gasoline. Idk what to do
AaronM 02-28-2013 11:36 AM
Originally Posted by FrenchToast (Post 7299509)
Lugging the engine under 2k where it has no torque, and therefore making it work harder than it should, probably burns more fuel than driving it above 2k where there is torque.
Nope. You'll get MUCH better economy at low RPM with open throttle than you will from higher RPM and less throttle. Ideally, for maximum economy you'd want to be in the highest gear possible without lugging the engine.
As far as a blanket "never under 2,000 RPM" rule, that's just not a thing. The RPM at which an engine is lugging varies based on load, amount of throttle applied, and the gear you're in. Running at 1,000 RPM in 2nd gear is fine. Running at 1,000 RPM in 5th is definitely not.
That said, I certainly wouldn't be shifting into 5th at 35 mph with my 951 (45 is my lower limit for 5th gear, and that's only on level ground when I'm not going to be accelerating), but I believe that the 951 has taller ratios than the NA cars so the comparison might not be terribly accurate.
mikepellegrini 02-28-2013 11:37 AM
<div class="pre-quote">
Quote de <strong>mikepellegrini</strong>
</div>
<div class="post-quote">
<div style="font-style:italic">I believe that's right. About 3k at 115. The car was just coming into the power band. <br>
<br>
Sure I do use 5th on the freeway, cruising along at 70. But that's about it. If I'm driving local, it hardly ever gets out of 4th.</div>
</div>
<!-- END TEMPLATE: bbcode_quote -->It should be at least 5k for a stock tranny, has yours been modified?
My 951.
