-   -   Can someone explain this (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/736422-can-someone-explain.html)
pfarah 03-10-2013 06:30 PM
There's definitely a sweet spot when the car pulls nicely.
Gawernator 03-10-2013 10:34 PM
I will say if I am feeling rich and adventurous I definitely shift closer to 3k, I do love the engine sound and the power, I actually have pulled away from traffic a few times with minimal effort. However I love being economical, lol. The only gear you need to shift higher than the low 2k is into fifth
Trevorlw 03-10-2013 10:39 PM
Explanation:
Your car is not used to the new fuel ratio and control. Try and clean your TB if you haven't.
Anything that has something to do with the Fuel/Air Mixture Ratio, You wanna make sure is working to the full potential.
Other then that, just drive it a couple times and see if it acts up anymore. If anything you should make sure you unplugged the Battery for a while. I would suggest 12 Hours. Or Over night so your Computer re-learns everything and re-learns your Rail/etc.
P.S. I would never use silicone Teflon of a sort. Just in my own opinion, the smoke was from the cleaner you sprayed. Was just burning off the motor.
gL
Gawernator 03-10-2013 10:58 PM
To recap on what happened, the smoke was water from me spraying down the engine bay earlier in the day. I have four new rebuilt injectors on, the TB is very clean and I rebuilt it with the Arnnworx kit. (Spent hours cleaning and painting Tb and intake manifold). The problem was a combination of one, leaking fuel injector, two, ICV needing to burn off the stuff inside which happened after a day of driving and three, tapping the ICV one last time and making sure the connector was on tight. Currently my 944 is driving like a dream. :)
Trevorlw 03-11-2013 01:56 AM
Glad to hear! ;)
