AFJuvat's Avatar
Porsche Crest R-134A conversion update...
So far everything seems to be fine. If I am lstill leaking, it is very slow. Vent temps have been holding in the high 40's during the day, can drop to 40 at night. No adverse effects noted so far (corrosion etc....)
AFJuvat
Old 07-06-2002, 02:33 PM
Send a message via ICQ to fly944
good news
Glad to hear the good news. It sounds as if you are out of the woods. I wish the 911 could reach 40 degrees w/r134 conversion.
Old 07-06-2002, 06:56 PM
stray15's Avatar
Send a message via AIM to stray15
Wow, I didn't know you could get that cold with 134. I just put in 200 bucks worth of R12 in the other day for free. We did a test to see if it would hold a charge and it said it would. We will see, no loss for me since it was free.
Old 07-06-2002, 07:25 PM
Stray 15 your are lucky. I paid 100 for one and quarter pound of R-12.
AFJuvat, did you convert your system using a conversion kit available from auto part stores? Such as Pep boys?
I saw a kit today when I was there.
Maachan
Old 07-06-2002, 08:48 PM
stray15's Avatar
Maachan
Yeah tell me about it. One of the benifits of working at a garage and helping out the mechanic at times. At our shop we charge 25 bucks a quarter pound. I think 134 is like 8 bucks a pound. We don't charge that much for profit. It just cost so much to get the stuff these days.
I thought about doing a retrofit but I like it cold, and R12 is colder. So I'm told anyways.
Old 07-06-2002, 08:56 PM
AFJuvat's Avatar
Yeah, R-12 is colder without a doubt. But for those of us that even though we do work in a garage, R-12 is just so bloody expensive, 134 was a good comprimise.
Where I was kind of stuck is that I really didn't want to shell out the cash to really fix everything that is wrong with my AC (new compressor, new evaporator, reciever dryer and probably a hose or two...(the car has been in FL its whole life, so the AC has definately gotten a workout.)
AFJuvat
Old 07-06-2002, 10:09 PM
SoCal Driver's Avatar
Actually R-12 is still rather cheap as this is what the rest of the world still uses. Like a gallon of gas in Europe where 80% of the cost is taxes, the same holds here for R-12. The tentacles of socialism at work.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 07-07-2002, 01:44 PM
conversion problems
Hey guys. I just tried fixing up my AC a week ago. I had Pep Boys vaccum the system down after putting in a new drier. I then tried to use the R134 conversion kit, but have run into a snag. The system took both cans of oil without a problem, but will not take the refridgerant. It took about the first 1/3 of one 12oz can, but won't suck any more in. I watched the compressor as I tried to charge it up, it clicked a few times, but never fully engaged. With the car off, I can spin the center section of the pulley (the part that doesn't spin when the engine is running) without any difficulty. I'm thinking something electrical is wrong, as I replaced the compressor a year or so ago for a verified functional used one. Is there an easy way to manually jump the compressor clutch and get the system charged correctly? I'm thinking it just needs a little push, as the other cars I've converted would cycle the compressor on for short bursts at first, then increasingly longer as the system filled. Its like my car isn't even to the point it can run the compressor at short bursts.
Any help with the issue. I took the car back to Pep Boys and they tried to tell me I'd have to pay them another $70 for an AC check even though they just did one on it.
Old 07-07-2002, 05:44 PM
I think there is a low pressure cut out switch located near reciever/dryer. If you fool that then the compressor would work, I think. You need to be carefull. The switch is there for a reason.
Maachan
Old 07-07-2002, 10:03 PM
stray15's Avatar
Cheap?
It costs a grand for a 30 lb tank.
Old 07-08-2002, 07:35 AM
Yeap, cheap.
$90 for the R-12, $910 for socialist imposed taxes most of the rest of the "developed" world doesn't pay.
Where do you think all of the black market R-12 comes from???
Oh yes; Dupont used to have the exclusive patent on R-12. Now that the patent has run out Dupont has the exclusive patent on R-134.
Interesting.
Old 07-08-2002, 07:59 AM
Gielamonster, The compressor clutch uses a 12v signal to turn on and off. Look for the electrical connector at the compressor. It should have two terminals. Run 12v to it and the clutch should engage. Good luck.
Rory
1986 951
1998 986
Old 07-08-2002, 11:24 AM
AFJuvat's Avatar
Yes, I used the kit from pep-boys. Actually discount auto parts, but you get the idea.
I rigged my air compressor to function as a pump, but I would recommend getting the system evacuated from a shop. Most places will do it for close to free seeing as you are giving them R-12.
I didn't even mess with the high side of the system, did everything from the low.
AFJuvat
Old 07-08-2002, 07:53 PM
http://www.griffiths.com/achelp/achelp4.htm
Has info that will help me, might help others too.
Old 07-09-2002, 11:06 AM
