Automatic transmission problem...Help please
I have a 1984 944 non turbo.
With normal driving acceleration,the 2nd to 3rd shifts at about 66kph.
I would like the trans to shift into 3rd under 60kph.
To get the trans to shift into 3rd at 60kph, I have to lift off the accelerator pedal for a second or two.
Is the shift point adjustable down to say 55kph?...if so how.
Old 03-29-2013, 04:02 PM
Proprietoristicly Refined
John_AZ's Avatar
I cannot give you an answer.
The last automatic I worked on was an old Audi 450SL.
Here is the WSM automatic pages with topics that may help.
There is an automatic transmission trouble shooting page in the WSM.
I do not know of a way to change the shift points.
Check your transmission fluid level and the shift cable????
GL & welcome
J_AZ
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 03-29-2013, 04:36 PM
AFM #725
Gawernator's Avatar
Wouldn't that be controlled by a computer
Old 03-29-2013, 09:17 PM
No computer on the early 944.
Are the shifts controlled by engine vacuum??
Old 03-29-2013, 10:30 PM
No vacuum lines going to the trans on these, and no computer control.
Old 03-30-2013, 07:02 AM
FLYGEEZER's Avatar
Downshift cable adjustment. The thing is too tight. Adjustment is on the throttle cam. Haynes manuel has the instructions to set the cable. Nothing to it.
Edgar
1984 Porsche 944 bone stock
1995 Mercedes E320 wagon
1970 Honda CB350 mint!!!
Old 03-30-2013, 08:24 AM
