Suspension Refresh(Questions)
I am looking to finally after 2 year redo the front suspension on my car. Car is mostly driven on the street, may seen an autocross this year if I can get everything done to it.
So the questions are:
1. Where to get bushings for the front control arms?(Swaybar, control arms) Can I get M030 rubber bushings for my car? (Are refurbing the arms really $500?)
2. Will 200 lb springs work well with Koni Strut Inserts?
3. Are the VW Fox strut mounts okay for the 86 951?
4. List of components to be replaced/fixed: Strut inserts, new front springs, control arm bushings/ball joints. Is there anything else I am missing on the front suspension?
A separate project will be to swap out my steering rack as mine is just puking fluid.
Old 04-03-2013, 02:21 PM
AFM #725
Gawernator's Avatar
Available here, of course! Porsche 924S/944/968 Suspension - Page 4
Sure you can look around though...
200 should work, I'm at 250 and it's quite a nice ride with the Koni 1038S inserts set to half firm (Koni race shocks rear)
Check for tie rod play? Just replaced mine, some inner play and one torn boot. Check your strut mount bearings for play or seizing etc
Swaybar bushings? Possible size upgrade? You could get these for cheap http://www.rennbay.com/porsche-944-front-sway-bar-braces-p-125.html
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio
http://www.gawerracing.com
Old 04-03-2013, 02:58 PM
I will be sticking with stock swaybars for now. In the future I may upgrade to the M030 swaybars.
Tie rod play should be 0 since I replaced the whole tie rods on both sides last year along with my front wheel bearings
Old 04-04-2013, 07:15 AM
Toofah King Bad
Rasta Monsta's Avatar
Headed for a common mistake. . .increasing the front spring rate and leaving the rears alone will make the car push. Turn in at AutoX could be particularly bad.
T-bars - much ado about nothing, not that big a deal.
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 04-04-2013, 08:25 AM
This is about the front suspension. Later I will think about redoing the torsion bars/carrier.
Old 04-04-2013, 09:32 AM
Toofah King Bad
I must have misunderstood. Thought you were wanting to AX the car. Mods you are contemplating will FUBAR the handling.
Old 04-04-2013, 09:45 AM
AFM #725
Gawernator's Avatar
Another reason I would recommend 220/250 etc springs... And in the rear either larger torsion bars or replace with coilover spring or both
Old 04-04-2013, 11:08 AM
Porsche 944S Club Sport
guru944's Avatar
Send a message via AIM to guru944
Billy M;
Consider Polyurethane sway bar bushings and endlinks for both front and rear. This will help minimize body roll, especially around at +15mph cornering. In expensive upgrade(s) Energy Suspension, Prothane and Ricochet make sutable upgrades. Verify (measure with Vernier Caliper) what MM bars you have before you order. Your local Autozone or Lindsey Racing are good sources...
Keep us posted, Later...
Guru944
2006 955 Cayenne S Titanium Series - Marine Blue, 1987 Porsche 944S Club Sport.
1987 Buick Turbo-T Lightweight "Great White", +500HP, TA49 Turbo.
http://www.blackbirdmotorsports.com, 944/951/968, 911 and 955/957 Performance Solutions.
Thank you Lord, for your Loving Kindness, Tender Mercy, and Grace. Only You are Faithful.
Old 04-04-2013, 11:53 AM
guru944's Avatar
For all;
Great site for suspension upgrades & These guys are serious....
ELEPHANT RACING Tech Topic, Polyurethane Bushings and Friction
Later
Guru944
Old 04-04-2013, 12:29 PM
AFM #725
Gawernator's Avatar
Autozone has sway bars for a 944? ...???
Old 04-04-2013, 03:31 PM
guru944's Avatar
Gawernator:
You got me! Ha. Ha.! Let me clarify, Autozone for the bushings Energy suspension Polyurethane Bushings (End links and inner bracket bushings for front & Rear).
Paid ~ $34.00 for a pair of Rear greasable Poly's for my 944 last year... Imagine that..
Later...
Guru944
Old 04-04-2013, 03:54 PM
Originally Posted by guru944 View Post
Gawernator:
Later...
Do you have part numbers for these bushings? Sounds cheaper than the other poly bushings. What about the front of the aluminum control arms any idea on this bushing?
Old 04-04-2013, 05:12 PM
AFM #725
Gawernator's Avatar
Yes, I'm curious too. Could switch to those when my rubber dies, maybe
Old 04-04-2013, 05:16 PM
guru944's Avatar
Enjoy all...
Prothane Link:
Universal Product Guide Page 1 | Prothane
Energy Suspension Link:
energysuspension.com | Sway Bar & End Link Bushings
Porsche Shop Link:
Porsche 944 Suspension Upgrades | Wishbone Bushes & Shock Absorber Dampers UK
Lindsey Racing:
SOLID BUSHINGS KIT at LINDSEY RACING - Your Porsche Performance Parts Center
Later.
Guru944
Old 04-04-2013, 07:42 PM
AFM #725
Gawernator's Avatar
Anyways. You're still not addressing the fact that you can't change the front without matching in the rear without screwing things up.
Old 04-04-2013, 08:48 PM
If you didn't read my previous post. I am currently only doing the front. I will get the rear after the front has been sorted. I have the front suspension, plus steering rack I need to do first. After that has been completed then I will move to the rear.
Old 04-05-2013, 06:55 AM
AFM #725
Gawernator's Avatar
It's something that needs to be changed at the same time
Old 04-05-2013, 10:51 AM
Toofah King Bad
Give it up, he isn't listening.
Old 04-06-2013, 10:42 AM
