-   -   This doesn't look right... (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/743684-doesnt-look-right.html)
emoore924 04-10-2013 09:48 AM
IIRC the VW rabbit/Golf uses the same one?
kcoyle 04-10-2013 05:36 PM
When you get them off and all cleaned up check for any wear before you go and repack 'em. You'll need a 8mm 12 pt "cheesehead" tool to get the bolts off, some good degreaser and some CV joint grease as well. Its also been said that its you should tighten the bolts back up with a torque wrench so factor all of that into your cost as well.
KC
Mike_944 04-10-2013 07:04 PM
KC
I've heard something about switching the joints to extend their lives. Would this be switching the outers with the inners?
And how many ft lbs? 32?
kcoyle 04-10-2013 07:20 PM
I think I switched mine left for right, inner for outer should do the same thing.
Clarks garage instructions with torque specs.
CV Joints - General Information, Removal, Installation, and Maintenance
Mike_944 04-10-2013 07:59 PM
Did you switch the left outer for the right outer and left inner for right inner?
Or some other combination.
kcoyle 04-11-2013 01:59 PM
I can't remember, just flip them so that they spin the other way say from CW to CCW.
Mike_944 04-14-2013 12:08 AM
Dont worry people, I bought the CV boots!
