Patrick
pfarah's Avatar
New Old Idle Problem
Here we go again...
The engine has been running great for a few weeks but it seems that as we are getting into warmer temps here in New England, she drops about 200-250 rpm when at operating temp. I've tested, replaced, coaxed, pleaded, begged, punched, hammered, and tickled just about every component that is even remotely associated with idle or throttle control. She drives like a dream under any throttle but lags (intermittently) when I release the gas. An interesting point; if I'm rolling at speed and shift into neutral, the idle is ok. Once she comes to a stop, then the idle drops down. There are times, however, when she idles perfectly so I'm very confused with this issue. One thing I plan on trying out tomorrow is; when she's at operating temp, I 'll tap on the DME (used but recently replaced) to see any engine speed variations just in case of a cold solder joint. I will graciously accept spells, potions, or just about anything else that will help. Thanks!!
1984 944 NA, constant tinkering
1983 "Beastie" - Safari Build
Old 05-04-2013, 03:54 PM
AFM #725
Gawernator's Avatar
My idle never makes up its mind either.
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio
http://www.gawerracing.com
Old 05-04-2013, 05:22 PM
Patrick
pfarah's Avatar
If I say it's annoying, it would be an understatement. She's just about 100% mechanically and then this _ _it starts up. I haven't had a chance to tap the DME yet (or anything else for that matter). Maybe this coming weekend.
Old 05-05-2013, 08:35 PM
porschetub's Avatar
Dirty ICV or bad AFM ?,perhaps an air leak,I won't suggest where coz there are a lots of places to look,good luck.
1985 944 2.7 motor,1989 VW Corrado 16v,57 project plastic speedster t4 power,1992 mk3 Golf,2005 a4 b7 qt avant 3.0 tdi,1987 mk2 Golf GTI,1973 914,2.2t to go in.
Past cars, 17 aircooled VW's and lots of BMW's
KP 13/3/1959-21/11/2014 RIP my best friend.
Old 05-06-2013, 05:04 AM
Patrick
pfarah's Avatar
You may be right as I tapped on the AFM, while at idle, and rpms changed a bit. I then drove her a couple of miles and the idle appeared to be ok. I had it open and cleaned up a few months ago so I guess it's time again...
Old 05-06-2013, 08:47 PM
AFM #725
Gawernator's Avatar
Try running a jumper wire in the diagnostic port to turn off the idle stabilizer and see how it idles... also a good time to check for vacuum leaks
Old 05-06-2013, 10:48 PM
Patrick
pfarah's Avatar
Gaw,
Since I tapped on the AFM, no problems. I think I'll reopen the unit and give a once over, again. Vacuum lines are good.
Old 05-07-2013, 09:48 AM
AFM #725
Gawernator's Avatar
Sweet! Good to hear you found the culprit
Old 05-07-2013, 10:55 AM
