winter-hater club member
actually, the late DME is expecting up to 5V, wide open. i think the whole setup would work, if you had a late DME. the early DME is expecting a lot more voltage. up to 9.6 volts, if my math is correct. yeah, you need a late DME.
2000 Corvette - ????, 2007 Buell XB9R - Astrid, 1996 Discovery - Piglet, 2000 Forester "COOL PRIUS!" - Nobody Ever |
or just an EMS, the late DME would throw a huge wrench in the system and I'd need to change a ton of stuff, an EMS would allow me to strip everything off and start from scratch. in the long run costing about the same.
nah. you could put a late DME right in there. i've done it. the only thing you have to change with a late DME is the AFM, again due to voltage, but you have already bypassed that issue.
hmmmmmmm well.... **** then. So I have a 85/2 with an auto as a 'parts car' this might just work... so I'd use the map for the late 85/2? what computer do I use? there are two... if memory serves
which computer in the 85/2? there is only one, IIRC. and i think you use the same map you are already using. let me look at lindsey's web page again.
yeah, same software map.
I'm like 99% positive that there is a different map. Cuz I had a HELL of a time getting the right one for the 84 na...
in fact, looking at the diagram you posted in #3, that is pretty close to what the late DME is expecting: 5v to the AFM and up to 4.5v back, +-.5v. i do think that the map would need some tweaking, as i think the voltage line should be more linear from bottom left to top right... but you'd have to see what is going on with the car running, i think, along with your wideband O2 setup.
well ****! So can I just plug the new DME into the old DME harness?
not saying that lindsey doesn't know his stuff... but the early 944 is an odd duck.
yeah the older cars are weird, and thats awesome! dave does know his ****! but sometimes some idiot like me catches him off guard..
okay, i gotta go to bed. have fun. post a new video, if you get a chance. that would be cool.
I'll do my best! I don't have a ton of free time, gotta get ready for school... but I want her running for the fall
any progress?
not yet, been working on a buddy's aquarium all day. HOWEVER I don't think taking out three screws and swapping DME's will take more than twenty minutes
Oh and in case anyone else is reading this IT IS S1 FOR THE DATA FILE!!!! S2 is a 19lbs boosted car (as far as I can tell) just thought I'd get that out in the open.
I ran the car with the 'new' DME and it ran much much better! I'll have a video up as soon as my crappy internet will let me! ![]() THANK YOU SO MUCH!! |
Alright!! here it is
20130804 213538 - YouTube So its shuddering and coughing when I 'punch it' and I think it might be running a little rich (12's) I need to get it out of the shop and run it for a bit, might wait for the weekend so I can annoy the campers... revving to 6-7k will make them real happy at 4 am haha
this is my take: running it in neutral is not the same as under load (obviously). if you have the ability to plug the tuning software into the car and tune it real time with a buddy driving and or making small adjustments, you'd probably be in good shape.
i really do think that the curve needs to be adjusted so that line pretty much starts at the bottom left corner and runs to the top right corner. that said, it was a heck of a lot better and actually ran. also, i think you are correct about the 19#. initially i thought that was injector size (lbs of fuel/hour). strong work!
2000 Corvette - ????, 2007 Buell XB9R - Astrid, 1996 Discovery - Piglet, 2000 Forester "COOL PRIUS!" - Nobody Ever Last edited by nynor; 08-05-2013 at 06:52 PM.. |
I talked to Dave Lindsey, unfortunately I'm running on 1.5 hours of sleep so I don't remember exactly what he said, but the 19# is 19 cubic feet per minute and is a calibrations table.... so whatever that means.
Sadly Abaco's software is not live tuning, I can't even monitor what the MAF is outputting to know where to make the changes. However I think I might hack the AEM wide band and make the MAF's 5V reading the 'tach' so I can see where its hot or cold and fine tune things there. It is a AEM wide band failsafe (worth every penny, thanks Julio from Bisimoto) so I can live monitor and record that, but otherwise I'm just running guess and check. If I can get the actual tach hooked up then I at least have a reference point to run off of but figuring out what wire is what is a little more complicated than expected, I don't exactly have time to sit down like I'd want and read the shop text, so I'm doing google key word searches in my free time. So far I've figured that there is a 'signal' wire on the back of the tach that triggers the coil, or electronic ignition, what that signal is I haven't the foggiest.. that and I'm not really in the mood to guess and check the wires as the gauge wasn't exactly cheap. So I'm starting another 12 day, well 10 day actually as this is my last stint before school, stretch at work and I'll have very limited time to work on the car. I want to get the headliner in so I can put my quarter windows in so I can have a 'sealed' car and not worry about rain, dust, animals, or theft.. and well I'm not exactly sure I see that happening, however the progress that has been made has been absolutely amazing!!! The car runs, and isn't cooking the paint off! I will hopefully have the headliner in by later this week and will then be able to take her out on the road. I've also got my 911sc to work on so I should be kept busy! I just wish I had a little longer for summer break so I could devote a week or two into just the car.. she deserves it.. |
