rear hatch doesn't open with the key
I have a 1989 944 S2 that the rear hatch only opens from the button in the car but not when you are outside and use the key. The key turns freely but does not unlock the hatch.
Any ideas of what to look for?
thanks,
Old 07-28-2013, 06:35 AM
968 GUY's Avatar
check the microswitch at the lock for proper adjustment or if it needs replacement.
87 951 all stock exc. cup II's /94 968 6-spd, lowered,17in. RUF Speedlines, M030 anti- sways/ 94 968 Tip, Cup II's, otherwise stock
Old 07-28-2013, 08:55 AM
944 addict
mytrplseven's Avatar
Send a message via AIM to mytrplseven
If you pull back the carpet and look at the mechanism while you're operating it with the key, you'll quickly see what's not happening.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman.
Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved.
Old 07-28-2013, 09:06 AM
thanks for the info. i went to the micro switch and it is clicking but it is not sending out any power. there are three wires. one has juice all the time. the other two don't get anything when i turn the key. probably the micro switch.
any help on where i can get that switch?
Old 07-28-2013, 11:04 AM
I think I saw the interior switch here maybe they have the micro switch as well? If not, it is avail on line. In the same vein, my micro switch works fine but I do not have 12 V into the switch from the body harness. Any ideas on where to check for a bad feed?
Old 07-30-2013, 08:15 AM
