a new running problem
TG this forum is here for people like myself and so many willing to help! The one topic makes me laugh is "What did you do to your car today" and I often think to myself, considered burning it!
So today I am driving down the road and it just shut off and we coasted to the side of the road, but think I to myself it did this last year so out of the glove box I pull the new DME sensor I have there and quickly swap it out, but alas, that's not the problem. I have 2 new ones and the old one, none cured it!
T would start and idle for about 30 sec then die. after about 1/2 hr it cooled off or whatever and ran off and on long enough to get home. There was 1/2 tank + of gas and water temp was normal.
Does anyone have any idea on what this dam gremlin could be? I hate it when I am afraid to go anywhere with it!
Also, anyone know if I can unplug and remove the alarm module without any problem as far as driving it?
Thanks all of you in advance
Old 07-13-2013, 01:28 PM
944 addict
mytrplseven's Avatar
Send a message via AIM to mytrplseven
What's the status of your fuel system? Have you replaced the fuel filter to see if you are getting fuel? It's a quick and easy check. Could also be a failing fuel pump or plugged strainer. When the engine was running, could you romp on it and get high performance or do you simply drive "quietly" around town?
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman.
Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved.
Old 07-13-2013, 03:39 PM
Sugar Scoops Rule :)
dave 911's Avatar
A buddy of mine who knows 944s says this could be the coolant temperature sensor.
Dave
_______________________________________________
'76 911S Targa
'62 VW Type 1 Sunroof
'73 914 2.0 (1st Porsche, gone long ago but not forgotton)
Old 07-13-2013, 05:11 PM
I had a temperature sensor go bad and all it did was make the radiator fans run nonstop even when the car was off and cooled down. I would have to disconnect the battery every time I left it for several hours or it would end up dead. Finally replaced it a couple months ago.
I would check the fuel system first.
Currently have: Guards Red 1987 924S 16v -- Light Blue Metallic 1980 928
Gone: Minerva Blue 1979 928 -- Gray 1985.5 944 -- Black 1989 944 -- Black 1984 944 -- Black 1987 944S -- Alaska Blue 1974 914 1.8 -- Guards Red 1983 944 -- Guards Red 1987 924S -- White 1988 924S -- Maraschino Red 1987 944 Turbo -- Beige 1981 924 -- Red 1984 944
Old 07-13-2013, 10:32 PM
the funny thing is, the day before I drove about 50 miles on the highway with NP, and this was about 5 miles from home on the highway
This cars electrics drive me nuts LOL
Old 07-14-2013, 06:49 AM
944 addict
car shutting down
In addition to my initial post, I'll pass along another note or two. DME relays, especially older versions, have been known to be faulty. There's an updated version that should be used. I'm reluctant to think that this is the issue. Also I don't think it is a temperature related issue because it sounds like you were at normal operating temp for some time before the car shut off.
Autozone, a autoparts company, will loan fuel pressure testing kits and I used them to completely test my system, including fuel pressure regulators, fuel dampers and fuel pump and check valve functions (per the tests in clark's garage) and it cost me only an adapter fitting and some clear plastic hose purchased at home depot.
If you have a loose connection on the DME cable or a bad solder joint in the circuit board, this could account for the stoppage that comes out of no-where. A loose connection or defective ignition switch could also be a culprit. You might see if moving the connectors described in this post (while the engine is running) to see if anything changes. Also consider the grounds around the car. Intermittent issues of this sort have been traced to faulty grounds.
Old 07-14-2013, 06:54 AM
Patrick
pfarah's Avatar
Peter,
Did you have a chance to test the speed and reference sensors? This happened to me over the winter where I was driving along fine then she just cut out and died. Thankfully, it was only 13 miles from the house... Clarks Garage has a good test procedure; a quick test is to view the tach for a "bounce" while turning over the engine. Good luck!
1984 944 NA, constant tinkering
1983 "Beastie" - Safari Build
Old 07-14-2013, 09:04 AM
thanks again all of you
Old 07-14-2013, 10:58 AM
Damm, I have checked it all and it still stalls however I have to add that it seems to be ambient temp related. It only happens when its very hot out. Driving me nuts LOL
Old 07-16-2013, 05:22 AM
"heat related" where you are hopefully is bit less of a problem! Kidding, in my turbo Audi experience, one of the speed ref sensors can get heat soaked when they are getting on in life but will rejuvenate when cooler. We would carry a 2 liter Coke bottle with water to douse the sensor when failed to see if it would then go. The Audi had 2 similar speed ref sensors, one for only start up and one referenced while running. The second was the problem. The other heat issue could be vapor lock, not something I've heard really associated with this car either though. In the turbo Audis this would manifest more often on restart, especially with a weak fuel pump check valve thrown in the mix. Good luck.
Old 07-16-2013, 05:35 AM
thanks
Old 07-17-2013, 05:24 AM
wrench1's Avatar
We had the same problems late last year with both of my sons cars, two different items caused the problem.
After checking the filters, sensors and fuel pressure we found the fuel pump would quit after 15-45 minutes in the 83 car.
The DME computer once warm would give up in the 88 car.
Replaced the fuel pump and re-soldered one broken joint in the DME.
Fuel pump and DME are easy repairs. Do you have access to a known good DME?
Both running well now, good luck.
Old 07-17-2013, 06:28 AM
unfortunately , I do not, wish I did. Perhaps I should try the local junk yards, this is one of the negatives of living in a rural area
Old 07-18-2013, 04:17 AM
GreenWater's Avatar
All good advise. I would guess that it's not the coolant temp sensor. I had one go bad on me. The car would start up cold and run forever just fine. But if you turned it off after it's warmed up, the car just wouldn't start up again until it cooled off. The coolant temp sensor tells the DME what fuel/air mixture to give the engine. If it's broke it gets confused and gives the engine either too much or not enough fuel/air. So I don't think this is your problem. Just for fun, I started the car and then pulled the wires off the temp sensor and the car runs just fine.
But, like we all know, there's just no rules with it comes to 944 issues. Especially electrical ones.
I have considered burning my car, many time.(literally) But don't, just remember how much fun they are when they are running good.
Good Luck.
www.Only944.com Porsche parts, Only better, Only944
87 944 N/A 165,000 miles
84 944
Saved by God, because I could not.
Old 07-18-2013, 10:02 PM
LOL, only kidding on the burning but I have no idea on why Porsche made the electrical system so complicated, drives me nuts
Old 07-19-2013, 11:26 AM
Can't tell you how many times it's crossed my mind.
Old 07-19-2013, 11:57 AM
