| uvachief |  Tach works but the MPG dial only moves intermittently
			I've got a late 944 na 5 spd that has a working tachometer but the MPG dial sticks from time to time.  When you pull up to a stop, it will generally kick on and start fluctuating.  Use to happen once in a while. Now it is very common.  Aren't they part of the same cluster?  Why would one work but not the other.
				__________________ Sincerely, uvachief  1986 944 NA Red 5SPD | ||
|  07-22-2013, 10:06 AM |
| Moderator |
			So does mine. I haven't figured out what's causing it yet. Please let me know if you figure it out.
				__________________ www.Only944.com Porsche parts, Only better, Only944 87 944 N/A 165,000 miles 84 944 Saved by God, because I could not. | ||
|  07-22-2013, 11:39 AM |
| Moderator |
			I just remembered that someone here said that it could be the gauge and that I should take the gauge out of the cluster and clean the connections. I think I did it? I can't remember now. But my gauge still doesn't work.
|  07-22-2013, 11:43 AM |
| uvachief |
|  07-23-2013, 11:36 PM |
| Moderator |
			Mine jumps around about 5-10 MPG. Interesting red gauge surroundings. Looks cool.
|  07-24-2013, 07:10 PM |
| AFM #725 |
			Your cluster looks sweet! I'd say try cleaning the electrical insides
|  07-24-2013, 08:24 PM |
| uvachief |
			Took it out so many times working on odometer gremlins that I painted it red when I got ticked at it one day.  Need to find a matching red shift boot cover.
|  07-25-2013, 01:58 AM |
| AFM #725 |
			Where did you get white needles? I'm sure Kyle/Greenwater could assist with your shift boot.. ^_^
|  07-25-2013, 07:57 AM |
| Moderator |
			I didn't even see the white needles. I like it. I will have to do that to mine next time I take it apart. Two more things I just noticed. I don't remember seeing the VDO on my gauge surroundings.(middle bottom) The second thing, what does it say on the bottom of the speedo? Thanks Andrew, I was thinking the same thing. I CAN make you a red shifter cover. Check out the other covers we sell and let me know if you want a red cover. Shifter Covers Just PM me or email me. A red vinyl cover should be the same price as the black vinyl.($15) I should start doing custom covers. It's easy enough and I've done them before. I will have to add that to the site. Thanks Andrew.
|  07-25-2013, 11:13 PM |
| AFM #725 |
			Looks to me like it says "WOW!" Haha, anytime.  If only I had a carbon fiber shift boot... oh wait.. xD
				__________________ Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio http://www.gawerracing.com | ||
|  07-25-2013, 11:37 PM |
| uvachief |
Hand painted those as well.
|  07-26-2013, 10:20 AM |
| uvachief | Quote:
|  07-26-2013, 10:22 AM |
| uvachief |
Oh yeah it says WOW!  Those are stickers but you sure cannot tell.  I had other really bad ideas but didn't do them.  Like at 88 mpg I was going to put B2TF for Back to the Future.  At 100 I was going to put JAIL.
|  07-26-2013, 10:25 AM |
| Frankly my dear.... |
I like the optimism   I think I would have put - Never! ^^ LOL - 88 mpg??? If only...  .... perhaps 88 MPH?
				__________________ Porsche - accept no substitute Blue 1999 Boxster - Brief encounter! Black 1988 944S - Ongoing project Black 1987 944S - Gone but not forgotten Metallic Black 1980 924 - Those were the days.... Red 1979 924 - Hmm Minerva blue 1979 924 - Where it all began! | ||
|  07-26-2013, 01:24 PM |
| uvachief |
			Odd...replacing the starter seems to have cured the stuck mpg needle. Sent from my SCH-I545 using Tapatalk
|  12-27-2013, 11:27 AM |
| Banned Join Date: Jul 2011 Location: St Paul MN
			bad ground somewhere you fixed in the starter?
|  12-27-2013, 11:31 AM |
| Registered User Join Date: Jan 2011
			which cars received the mpg gauge? i don't hae one    | ||
|  12-27-2013, 12:28 PM |
| Moderator |
			The earlier cars have a mpg gauge, my 85.5 does, but my 87 doesn't.
|  12-27-2013, 01:49 PM |
| Moderator |
			I probably have a bad ground somewhere too, but my starter works fine.
|  12-27-2013, 01:50 PM |
| uvachief |
			Manual - 86 has one.  That is a late model.  Automatics of course do not. Sent from my SCH-I545 using Tapatalk
|  12-27-2013, 11:18 PM |
| Tags |
| tachometer |
