Wrench Therapy Inc.
Lightbulb Stupid odometer-Idon't know what's wrong!
so I've had the odometer out of the car four times for it not operating correctly. I've had it out of the car and checked the gear and all the gears inside the mechanism and put it on a bench with the drill and it works correctly. I go back and put it in the car and hook it up to speed ometer cable and it works while driving around the block but when I come back and park it turn the key off and let it sit an hour, it then does not work ever again or at least until I take it out of the dash in and open it back up. it is a 1983 model and I have looked at all of the tutorial videos and all of the information on the post and done all the advice that has been given but I do not know why the odometer is so intermittent in its operation. I just need to know if I need to send it off to a reputable rebuilder or any other advice that would be greatly appreciated. I am curious about Hall effect sensor on the back will affect the operation of the odometer also. thank you very much.
Old 08-15-2013, 09:19 PM
83 944
I also have an 83 and I also had this problem. I have read of many others having this problem but never a definitive solution. All I can tell you is what I did to fix mine. This is as best I can recall.
Like you I had mine in and out several times and ran it on a drill. My best guess was that the drill clamps to the outside of that brass colored tube, while the cable shaft in the car seems to spin on the inside of it. My best guess was that the inner shaft receiver was slipping in it's brass tube. My "fix" was to clamp the drill chuck down on the brass tube and tighten very hard. I figured I might squeeze it all back together.
That was about a year ago. It's still working. Try it. Let me know.
Old 08-15-2013, 10:44 PM
Flagtie, I know this is stupid and not at all helpful, but I now have the image in mind of you driving around with a drill attached under the bonnet! :-)
What did you use when you fitted it to the car ? a small hose clamp?
Apologies and regards...
John
Novice mechanic.
1987 944S in need of TLC
Old 08-16-2013, 12:38 AM
the 83 odo is purely mechanical. every time when u remove the gauge, is the nut that holds the speedo cable to the gauge still tight?
Old 08-16-2013, 09:13 AM
83 944
Under the bonnet...ha ha. Actually, there wasn't enough room there. Instead I attached the tire side of the flexible shaft to a drill I keep in the car with me. As I drive down the street, I pull the drill trigger to keep the odometer turning.
Old 08-16-2013, 10:43 AM
AKCJ's Avatar
The odo on my 83 only worked part of the time also.
I just pulled out the speedo and sent it to a repair shop. Didn't cost much and it's been working well for many years since. I don't know the name of the shop but I do remember it was in Texas.
HTH
Red 83 944
Old 08-16-2013, 02:36 PM
Flagtie, I'd love to buy you a drink as you made me laugh. :-)
I'm sure you're not serious (are you?) Hahaha!
I haven't laughed so much in quite a while! :-)
John
Novice mechanic.
Old 08-17-2013, 04:10 PM
thekidd's Avatar
Send a message via AIM to thekidd
Is the cable secure at the front drivers side wheel? Take the dust cap off and check there. If it isn't, the speedo will work momentarily
Old 08-18-2013, 05:58 AM
Have you checked for a break in the cable itself?
1987 928S4
1992 968 cabrio
2009 957 Cayenne GTS
Old 08-18-2013, 10:37 AM
