uvachief
uvachief's Avatar
Send a message via Yahoo to uvachief
Remove and Replace DME Temp Sensor on 944 Late?
Anyone got a step by step walk through to remove and replace the DME temp sensor on a 86 944?
Sincerely,
uvachief
1986 944 NA Red 5SPD
Old 09-16-2013, 11:50 AM
Get a fluid evacuator (Mityvac or similar) and remove the bleed screw from the top of the coolant elbow on the front of the engine. Using a thin tube with the evacuator, insert the tube into the bleed opening and suck out the coolant down to the level of the sensor. Remove the wiring from the sensor. Remove the sensor with a deep socket. Install the new sensor and washer. Connect the wiring. Pour back the coolant and bleed the system. Install and tighten the bleed screw.
Old 09-16-2013, 12:45 PM
Proprietoristicly Refined
John_AZ's Avatar
Instead of a deep socket, I used a 'crows foot" worked well.
I put a thin bead of Curil T on the threads although it is probably not necessary.
You need to move the JBoot off of the TB but you do not have to disconnect the rest of the vac lines. Be gentle.
J_AZ
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 09-16-2013, 01:34 PM
AFM #725
Gawernator's Avatar
I just used a deep socket, unscrewed, screwed in and connected new sensor. Really easy. Get a shop rag to catch the small burp of coolant that will come out. Do it with the engine totally cold
Simple
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio
http://www.gawerracing.com
Old 09-16-2013, 03:51 PM
uvachief
uvachief's Avatar
Thanks. Anyone use FAE sensors since the Bosch ones didn't last 4 years?
Sincerely,
uvachief
Old 09-16-2013, 04:45 PM
1988 944 2.5L 8-v NA 301k
VirginiaF1's Avatar
Porsche Crest
Howdy Chief...
Yes, I changed out my DME TS earlier this year and went with the FAE..
So far so good..
Only had about 2-3 oz of cold coolant leech out the bung..
Took less than 20 mins tops..
GLWR
'88 8v n/a 301k with 41k on current TBelt
M454 M533 M650 M425 M418
New Feb'13 Bridgestone Grid 019.. awesome.
Paid just $1,700 running & inspected.
Big RUSH Fan! Lic Plate = LIFESON
Old 09-16-2013, 06:42 PM
AFM #725
Gawernator's Avatar
I spent the money and went with German VDO. Works great
Old 09-16-2013, 07:12 PM
944 addict
mytrplseven's Avatar
Send a message via AIM to mytrplseven
That was one of the easier projects I've had to deal with on these cars. As GAW said, unscrew it, replace it, re-bleed the system. Rags didn't have to deal with much coolant loss. Maybe an ounce.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman.
Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved.
Old 09-19-2013, 07:58 PM
uvachief
uvachief's Avatar
I an waiting on it. Fixed the starting issue.
Sincerely,
uvachief
Old 10-08-2013, 05:40 PM
Tags
dme temp sensor
