ruvysoho's Avatar
Angry turn signals causing car to stall
So i have been having some running problems with my 944s2 I have changed out almost every part now today had her running great till i got a little miss fire. then when I used my turn signal all my gauges went to 0 and my car ran like crap. When i let off the turn signal the car went back to normal. I tried it a few more times and id did it every time after that. Any one have any ideas or had the same problem ?
first Porsche 1971, 914, 2.0
second Porsche 1986, 944 n/a
third Porsche 1984, 944 n/a
fourth Porsche 1986 944 turbo
fifth Porsche 1991 944s2 cab
Old 09-24-2013, 10:43 AM
Under the car
I'm sure this doesn't help but whenever I hit my turn signal the seatbelt light in the center console of my early car lights up. If there is any relationship between these maybe someone will let us know.
Old 09-24-2013, 12:45 PM
ruvysoho's Avatar
lol this car is driving me nuts. I think i will sell it when i finally fix it and get a newer porsche maybe a cayman.
Old 09-24-2013, 01:06 PM
tamathumper's Avatar
Got a mouse in (or under) the fuse box?
'78 924 "NA"
'87 944 "S"
'93 968 "SC"
Old 09-24-2013, 01:12 PM
944 addict
mytrplseven's Avatar
Send a message via AIM to mytrplseven
I had a 2007 Cayman S and take it from me, you won't be sorry. Best car I ever owned. Hate to see you give up on a car because of a wierd problem, though. Just a question: Does it matter which direction the turn signal caused the issue (left or right)?
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman.
Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved.
Old 09-24-2013, 01:13 PM
Sounds like you may have a short in one of the turn signal lights. Do the turn signals all work with the engine off, ignition on. If one light doesn't work, disconnect it and see if the engine still has problems.
Clifton
Old 09-24-2013, 02:00 PM
ruvysoho's Avatar
does not matter what way you turn the signal it messes up. the car runs bad enough on its own but when you hit the turn signal it runs much worse its weird. I would not give up on this care but it is my daily driver and I cant afford to be dumping money in a car I cannot drive. I love the car but I need reliability.
Old 09-24-2013, 02:09 PM
Have you inspected your wiring? I'm not joking about the mouse.
'78 924 "NA"
'87 944 "S"
'93 968 "SC"
Old 09-24-2013, 02:45 PM
ruvysoho's Avatar
where should i start inspecting?
Old 09-24-2013, 03:06 PM
ruvysoho's Avatar
with the engine off i turn on the turn signals and they are very dim they flash but u can hardly see them
Old 09-24-2013, 03:27 PM
That's probably because there's a short between their wiring and a bunch of others...
For starters, I would check anywhere those wires come close to other wires - a good first place to look where most wires converge is in the fuse box. The second place would be right underneath the fuse box.
Do you have the wiring diagrams and parts manuals for the car?
'78 924 "NA"
'87 944 "S"
'93 968 "SC"
Old 09-24-2013, 04:20 PM
Just a guess but sounds like bad grounds under dash and for DME. Low voltage at DME getting even worse when you use the turn signal.
1987 944 Summer
2006 E90 Winter
Old 09-24-2013, 05:02 PM
Over 40 victim of fate
stogie25's Avatar
Start by pulling the fuses for the turn signals, and see if it happens. Try pulling the bulbs after that (with the fuses in). Try another switch (borrow one from a friend). Maybe the results will point you in a direction.
black 1988 Porsche 944 (30 years old and getting younger every day)
black 1997 Jeep Wrangler (very modified)
I didn't know cars came in other colors
Semper Fi
Old 09-25-2013, 03:15 AM
