Found a Turbo S engine
I have found a n '89 Turbo S engine for $1500.00 complete and running. I guess transplanting it into my '84 would be complicated. Would the NA tranny and brakes hold up ??
No.
Frankly my dear....
+1 on No...
Just for reference: ![]() Of course, you could fit the motor, but you really do need to upgrade so much to make it safe and perform well .
Porsche - accept no substitute Blue 1999 Boxster - Brief encounter! Black 1988 944S - Ongoing project Black 1987 944S - Gone but not forgotten Metallic Black 1980 924 - Those were the days.... Red 1979 924 - Hmm Minerva blue 1979 924 - Where it all began! |
Well....you are off to a better start than trying to turbo the N/A motor. Fit the motor and exhaust.....then start upgrading the suspension, brakes, transaxle etc.
You will spend more money.....but if the car is near and dear to your heart.....keep it and upgrade it.
10 E92 M3 13 Jeep GC Limited 98 Jeep Cherokee 87 951 C3 Stingray |
+1 if you have access to that motor at that price and your 84 is in excellent condition I wouldn't hesitate dropping that motor in there. Make sure you have the motor, harness, DME, KLR, and all the piping and heat shields to go with it.
You will probably need a whole bunch of spurious body and other parts to make it fit but those are available cheap used or aftermarket. Just don't turn up the boost or drive it hard until you have time and money to upgrade your trans, suspension and brakes. |
Dog-faced pony soldier
Brakes would be okay for daily use, ditto transmission. For aggressive or modded use, they'd be the limiting factors. Doubt the transmission would explode but if nothing else the gearing would be sub-optimal.
I suggest you send it to me for further testing and analysis.
A car, a 911, a motorbike and a few surfboards Black Cars Matter |
turbo s
Just tempted to perform the transplant. You don't come across a Turbo S motor too often, but there's a lot to it.
condition was not impressive. |
Frankly my dear....
![]() Who is going to drive carefully with a turbo engine..? The strain it places on the transmission is not trivial, that is why the turbo box is 'beefed up' and the oil is cooled, etc.However, we are talking about a turbo S engine - even more horses, more torque, a few spirited clutch drops and the box will be toast. Over here in the UK, if you did that swap and didn't upgrade the brakes - in the event of an accident the insurance assessor would inspect the vehicle and could refuse any claim..
Frankly my dear....
Hi 9FF, are you saying that your 1986 T has the same spec transaxle as a standard 944?
I had been lead to believe that the standard turbo transaxle is a strengthened variant of the base 944 unit, and that it went through further strengthening for the TS model, That is why I said the turbo box is 'beefed up', am I wrong somewhere here? I understand that the oil cooler started as standard equipment, then went optional, then came back as standard on the TS. So, I expect that Porsche realised it perhaps was not too necessary for the road in the 220HP Turbo, but really was in the 250HP S model. This type of conversion will always divide opinion, but I don't think that putting 250HP through a box designed for 150HP will be very reliable unless you treat it very carefully, which will kind of defeat the whole point of the work. Most of the posters in this thread (inc. yourself) have said that the brakes and transmission should be upgraded - Hey, we are all on the same page ![]() All that said, I do not have first-hand experience of this swap, just know some guys who tried it and it failed. However, they might have been driving the thing like it was stolen - I don't know...
All I'm saying is that I have been running more power through it than a stock TurboS for a long time without any issues whatsoever....and I certainly don't baby it. Last edited by 9FF; 10-29-2013 at 05:53 PM.. |
Frankly my dear....
I thought they put 016R (or S) boxes in the stock 951?
Just had a check on Clarks, that's what they say too..? Is it the original unit? If it is a J then you have a good one! All the best..
AFM #725
You could certainly buy that and find a 951 with a blown motor and bam!!! S.
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio http://www.gawerracing.com |
Do the swap, keep an eye out for a turbo transmission. Don't worry about the brakes unless you drive the autobahn or track the car.
Ornery Bastard
However, given that replacing the r&p in a 944 transaxle is a labor-intensive process and setting the lash is fiddly (plus the relative lack of availability of the r&p as a separate part) it's generally cheaper and easier to just get a turbo transaxle. I would NOT use a 944 NA transaxle with a turbo engine. It's just asking to blow apart the ring and pinion.
--------- Silver 1998 Volvo S70 T5 <- Daily (Anja) Guards Red 1986 951 <- Seattle car (Gretchen) White 1976 914 2.0 F.I. <- Prodigal car, traded away then brought back again (Lorelei) |
What about all the intercooler, plumbing and venting? You can't just run a vented nose panel and hope that works.
Patrick Youtube 333pg333 86 modified 951 |
There is a "free for the taking" 951 trans on the Maine C.L. - just search "Porsche" in the auto parts section. No oil cooler (non lsd) and needs a seal...but sounds good otherwise.
