Consequence of mixing up lifters?
Greetings,
In the process of removing the cam assembly on my 87 951, even being a careful as I could be, I still managed to have a couple of lifters slide out (no damage). I am almost certain that I have them all back in their original locations - but not 100% certain. If I somehow didn't manage to get them all back in their original locations what are the consequences? (All I have ever known is that it is important to get them all back in their original locations, not what happens if I don't).
Thanks!
Old 06-05-2014, 05:59 PM
944tothefloor's Avatar
Its best to get them back in correctly, but youll be fine. Your not the first one to maybe mix them up. Your only alternative is to buy new ones anyway.
Old 06-05-2014, 06:34 PM
Back from Beyond
Accelerated wear as they get happy with their new homes. That's all.
Old 06-05-2014, 07:50 PM
In practice, this doesn't seem to amount to much of an issue. The cams are extremely hard. When we measure them for compliance reasons, it is always amazing how little wear there is. Tolerances were pretty tight on the lifters. I wouldn't stress too much. In 944 Spec we prefer good used lifters to the crappy INA replacements in any case.
Eric Kuhns
NASA Great Lakes Super Touring Series Director
2007 & 2008 944 Spec National Champion
2015 NASA Eastern Champs 2nd place in ST2 "Franken44"
Old 06-05-2014, 08:14 PM
Straight shooter
Lapkritis's Avatar
Clean them thoroughly (diesel fuel or wd40 soaking/scrub) and then reinstall with a good bath of assembly lube all over. A dab of lube on top of the valve stem where they make contact with the bottom of the lifter is also good idea. Although I like to keep them in order I've never seen any indicators of accelerated wear or other problems when they're mixed - cleanliness is far, far more important to reduce wear.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.”
― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values
Old 06-06-2014, 10:08 AM
Andrew Gawers' Dad
CHICKS's Avatar
I hade like 30 lifters soaking in oil and I picked the best ones when I did my motor build. You'll be ok.
Old 06-06-2014, 11:10 AM
Many thanks.
I had assumed that barring existing wear that this shouldn't too be much a problem (at least I couldn't think of any reason that it would be - but what do I know?) but feel much better now knowing. I certainly didn't want to have to replace any of them. All the lifters look really good with no real visible wear showing so, after all your replies, I feel pretty safe now.
Thanks again.
Old 06-06-2014, 06:19 PM
Just thinking out loud
mattdavis11's Avatar
None. Mine are in different holes with a different camshaft.
91 FJ80
84 Ram Charger (now gone)
Old 06-06-2014, 07:06 PM
Banned
refund
Aj, how about a call to settle up? 706-392-2580 Mark
Old 06-07-2014, 05:24 AM
Banned
Does anyone on this forum personally know this seller 944tothefloor?
He is not to be trusted. See my post under classifieds and manual sport seat for sale or pm me for details.
Old 06-09-2014, 08:33 AM
Tags
944 turbo , lifters
