rmcdonnell's Avatar
Sump hooking up on something
First time taking the sump off, all bolts are out, it's lifting away by a few inches all round, but something to do with the oil pickup or some strap is catching when I try to lift the sump pan away. Give me a clue someone, Clarks doesn't mention it, do I unbolt the oil pickup through the gap, or is it something to do with the sensor on the outside of the pan poking in. I don't just want to pull hard..!
I'll get some light in there sometime tomorrow, but just wondered who knows what this is..?
cheers
Rissole
944 Alpine White '89 2.7L
Old 11-01-2014, 10:49 AM
Remove the sensor, once it is removed you should be able to maneuver it off of the oil pick-up. Do not try to muscle it off or you may be buying a new baffle.
1981 924 Turbo
1987 N/A Auto
Black w/Can-Can Red Interior
Old 11-01-2014, 11:10 AM
rmcdonnell's Avatar
Many thanks. I had the three bolts out for the sensor but it seemed stuck on there pretty hard. If it has to come out, so be it.
cheers
Rissole
Old 11-01-2014, 11:34 AM
In the Fires of Hell.....
kdjones2000's Avatar
You have to twist it around quite a bit for you to get it out, but you won't be able to drop the oil pan until you do.
Good luck..
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 11-01-2014, 01:13 PM
rmcdonnell's Avatar
Success: and uh oh.
Thanks for the advice, the sensor it was, or rather, the level sender Porsche call it. Got that out, got the sump off, and sitting on top of the oil filter gauze (my engine is upside down on a stand) was a small 1/4inch square bit of polished metal, that I think is part of the skirt of piston number 3.
Suprised something so minor could cause so much clanking, but hey...
When I've got a decent photo, I shall reveal the grisly detail.
cheers
Rissole
Old 11-01-2014, 04:43 PM
