1984 speedometer input?
I have a 1986 automatic 944 and just changed the transmission.
The transmission I mounted is from a 1984 model. It works fine but my speedometer doesn't work anymore for the obvious reason there is nothing to plug the connector on the top of the transaxle.
Does anyone knows where from the speedometer gets its input on the 1984 model - because it seems to be definitely different than the post 185 1/2 models ?
Jean
Old 10-14-2002, 10:18 AM
SoCal Driver's Avatar
Cable to the left front wheel though a hole drilled down the center of the spindle. End of cable engages the grease cup on the end of the hub. You could get the early spindle and put it on your later model but the speedo for the later models is totally electric -- no place for a cable. Can't even swap the old one into the newer instrument cluster.
Something about a sewage creek and no paddle goes here.
Guess you need to find a conversion chart for the gear and rpm's or a late model automatic transmission.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 10-14-2002, 11:49 AM
The speedo on all 944 models up to 1/85 is by cable off the left front wheel. There is no way of installing a cable-drive speedo into your car. Get the shop to carefully check the new trans as during the change over years some transmissions (at least the manual versions, don't know about autos) had the casting for the electric speedo. Otherwise, if you need the sppedo to work you need the correct transmission. If the diff was ok, you can just change the diff unit onto the new trans, but make sure you do change all the o-rings.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 10-14-2002, 11:50 AM
