JBC JBC is offline
JBC's Avatar
Jumpy Temp Gauge
My engine temp gauge will typically run a little over the midrange temperature mark while driving around town. It goes to the third temp mark and stops, typically. However, it will also occasionally bounce around wildly from max temp back to mid range rapidly and then settle down. It is simply a bad temp switch? Should I just replace the temp switch and the thermostat?
Old 12-07-2014, 07:46 PM
Toofah King Bad
Rasta Monsta's Avatar
On an 83, this can be caused by poor grounding at the following locations: under the dash, between the engine and tub, between the battery and the tub, between the battery and the engine, or a loose connector at the sending unit.
Solution is to take apart grounds, clean them with a wire brush and small file, and reassemble with conductive grease. If you are serious about driving the car for a long time, also consider refreshing the battery cables and alternator harness.
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 12-07-2014, 11:43 PM
JBC JBC is offline
JBC's Avatar
Rasta, thanks, I will check them all. JBC
Old 12-08-2014, 11:51 AM
JBC JBC is offline
JBC's Avatar
I removed the electrical clamp to the engine temperature sensor and found a lot of white corrosion under the clamp. So, I wired brushed it clean, applied conductive grease and put it back on. It seems to work.
Old 12-08-2014, 05:08 PM
