thamlin000's Avatar
Jacking Question
Can a 944 be jacked up (using a floor jack) by the cross member under the engine.
The present: 83 944, 77 911S
The past: 95 911, 67 912, 76 912E
Old 10-18-2002, 01:35 PM
ae1969's Avatar
Send a message via ICQ to ae1969
The crossmember is not a good place..... that piece of aluminum may hold, but its not a good stresspoint.
One of the major downsides of the 944 series are jacking points.
Right now I have mine about 18 inches of the ground on the four corner points and thats scary enough for me.....
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 10-18-2002, 04:23 PM
SoCal Driver's Avatar
Yes use the cross member. Just get the jack in the center and watch out for any leaning.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 10-18-2002, 04:31 PM
Mike B's Avatar
I know what you mean Alex...I had mine about 28" off the ground (as I dropped / installed my engine from the bottom) and was a little concerned the first few times I slid under there...But it was solid...Never had a problem...
I used the jacking points to raise it but when I needed help and took the car to Marc ( www.alpineautowerks.com ) ...When it was time to get it back on the ground he slid his floorjack under the cross member without a concern...I trust this guy implicitly with anything Porsche...His knowledge is endless.
Old 10-18-2002, 04:42 PM
rbt944's Avatar
I need to lift my car also and was wondering about the same thing. Will I need to get one of those special jacks that fit cars that are lower since it seems that my normal one won't go under there?
RBT.
-Gus
2000 kawasaki zx6r
1984__944.
pictures
Old 10-18-2002, 05:16 PM
I do not like to use the crossmember; I use the stub frames with a u shaped piece of 10 gauge welded to a steel dowel that fits into the cradle of my jack. If you use the crossmember, spread out the force with a piece of 2 x 6 and make certain it does not move. It depends on what you want to reach where you jack it. There are a number of points that will take the stress if you are careful. The rear is a bit more problematical; I have never had a problem jacking with a cup shaped insert in the jack socket right under the place where the torsion bar comes out and attaches to the suspension arm. It is strong; probably one of the strongest places on the car!!!
Just make certain you spread out the force as much as possible. I never recommend the use of a "bottle jack" for lifting a 944..too concentrated.
Good luck.
Bob S. former owner of a 1984 silver 944
Old 10-18-2002, 08:19 PM
ae1969's Avatar
well..... I guess when it comes time to drop her down....
The cross member it is ...........with a big piece of wood in between!
Old 10-18-2002, 08:41 PM
todwic's Avatar
Send a message via AIM to todwic Send a message via Yahoo to todwic
I use a 'neric 2.5 ton floor jack from Autozone. to get all four wheels off of the ground (as I did when I replaced the flex disc) I use the recomended jacking pt. in the middle and put jack stands on the 4 pt. areas for garage lifts. just do one side at a time.
*Disclaimer: The person above is actually dumber than he appears.
my web site Torque values maintainance and repairs lots of my rebuild pics weights and measurements
'84 944 auto/ps/ac/cc
'86 951
Providing ignorance one post at a time.
Old 10-18-2002, 09:13 PM
least common denominator
scottmandue's Avatar
Originally posted by todwic
I use a 2.5 ton floor jack from Autozone. to get all four wheels off of the ground I use the recomended jacking pt. in the middle and put jack stands on the 4 pt. areas for garage lifts. just do one side at a time.
I do exactly the same, no problem.
ae1969, RBT: Are your cars lowered?
Gary Fisher 29er
2019 Kia Stinger 2.0t gone
1995 Miata Sold
1984 944 Sold
Old 10-19-2002, 12:49 PM
rbt944's Avatar
Scott, my car is not lowered. I just don't think that my jack could slide under there to where the crossmember is. I think I may just go with lifting one side at a time like todwic said.
RBT.
-Gus
2000 kawasaki zx6r
1984__944.
pictures
Old 10-19-2002, 05:24 PM
thamlin000's Avatar
Thanks for the replies.
I used the crossmember. My 944 now has bilstiens up front. It rides much better.
Old 10-20-2002, 06:13 PM
