Garage Helper
Speed and reference sensors
Hello gang,
I ran into a quirky problem when working on my 85.5 944 - On the mount block that mounts the speed and reference sensors is a third sensor to the outside of the other two - I can find no reference to this third sensor in the manual or any place else. Pfunny time to run into something unknown as I have the mount block and other sensors pulled out - even have a washer filed down to .8mm and glued to old sensor for clearance purposes when re-mounting. What is this third sensor - what is it for - are their any clearance or mounting instructions for it????? TYVM in advance, Ed. (Thank you very much)
78-924 traded for 80-931 traded for 84-944 traded for 85.5-944 (7th one now). ![]() UAV-M1 (Urban Assault Vehicle - Model 1) Bless the lowered, and pass the nitromethane. Pedal to the metal till you see the gates of hell then brake NLA - No longer available is a four letter word |
Hi Ed, the third large opening is for a factory diagnostic plug which is no longer used.
Cheers, Larry
Retired USAF and Civil Service, 1985.5 NA Graphite Metallic, A never ending work in progress, 1992 968 Horizon Blue Cab "New Toy"
Garage Helper
Larry thanks so much - Couldn't hardly feel good about putting it back together with out knowing what that third sensor was for...
tyvm, Ed.
