Snowflake switch replacement?
I have a replacement A/C switch for my '87 944 N/A. Can anyone tell me how to get the old one out? Do I have to remove the clear plastic plate, and if so does it come out with it? Also, I could not get the fan speed knob off! Clearly this needs to come off if I have to remove the plate.
Thanks, Tom.
1987 944 Summer
2006 E90 Winter
Old 04-03-2015, 11:35 AM
In the Fires of Hell.....
kdjones2000's Avatar
Search is your friend...
Fixing up the climate control head
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 04-03-2015, 12:00 PM
Great pictures. I am still a bit confused! On an 87 is the switch socketed? If so can I pull it out? On one of these pictures the switch is in and on the next it is removed. Clearly I am missing something!!
1987 944 Summer
2006 E90 Winter
Old 04-03-2015, 12:08 PM
Yours is soldered... if only we could be so lucky
Old 04-03-2015, 03:10 PM
After much Googling I just came to that conclusion also. Not a huge deal since I have a number of people working for me who have de-solder stations. I can borrow one or even have an expert do it for me. Biggest worry is actually getting the back off without cracking everything. I think that I will wait for warmer weather so every thing is a bit more flexible.
Thanks for your help. For now I shall drive it to a bar. Still really happy about how a new oxygen sensor improved its running.
1987 944 Summer
2006 E90 Winter
Old 04-03-2015, 03:17 PM
mhariush's Avatar
if anyone doesn't want to go through all that trouble I have a whole unit great condition for $150
Current: 87 944S Black/Black, 89 944 Turbo S ANDIAL White/Burgundy, 78 924 Black/Black, 17 Cayenne S, 03 Turbo X50 Aero
instagram @mhariush http://stores.ebay.com/Techniker-Parts/
Old 04-03-2015, 04:16 PM
Done! The whole thing took just under an hour. It is a fiddley pain but not horrible. The biggest issue is that my hands shake like hell. I think I need to drink more, or is it less.
The hardest parts are just carefully getting the back off the unit and then getting the desoldered switch off of the front plate. I ended up cutting the little tabs that hold in in place off with a knife.
Well now my ac switch lights up and stays in.
1987 944 Summer
2006 E90 Winter
Old 04-04-2015, 08:38 AM
