mhariush's Avatar
89 944 (2.7L) alarm bypass issues
So, today I tried bypassing the alarm as per the Clark's Garage but then there was smoke...
I put the jumpers on terminal 1 and 4 and 7 and 8 as the instructions say. When I turned the ignition on the battery voltage dropped and there was a buzzing sound and white smoke coming from the 1 and 4 jumper. Tried one more time in case the jumpers weren't connecting properly. Same thing happened.
Is the 89 alarm different than the other alarms? What could cause this curious issue?
To give some back story... the car has/had intermittent start and run issue. Sometimes starts, sometimes not, and sometimes dies when running. I discovered that the negative battery cable was warm to the touch. So something was amiss. Discovered that what I thought was an aftermarket alarm from the stereo (blinking locking pin and no key on the fender) was actually a genuine hella alarm, I assume from the factory.
I have disconnected the power plug to the alarm and now the car fires up every time and keeps on running. At least in the 45 minutes I tested it.
Current: 87 944S Black/Black, 89 944 Turbo S ANDIAL White/Burgundy, 78 924 Black/Black, 17 Cayenne S, 03 Turbo X50 Aero
instagram @mhariush http://stores.ebay.com/Techniker-Parts/
Old 04-03-2015, 11:51 AM
In the Fires of Hell.....
kdjones2000's Avatar
Don't use that Clark's procedure on any 944 later than '86.
I have not seen a good bypass procedure for the later cars, sorry.
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 04-03-2015, 12:02 PM
mhariush's Avatar
That's interesting. I think Clark should put a note about that...
The bypass works on my '87 alarm.
Anywho, looks like pulling the power plug for the alarm did the trick.
I wonder... PO replaced the door handle and key on the driver side door. He didn't say when these issues started but perhaps they're related to the new door handle and key?
Thanks.
Old 04-03-2015, 12:06 PM
FrenchToast's Avatar
Yes, the alarm module changed in either '88 or '89.
As kdjones noted, that could be a third change - it could have also changed earlier.
Old 04-03-2015, 12:57 PM
