Need help trying to locate (1) screw
I have a 1985/2 944 automatic and I can't seem to locate (1) screw that is needed to reinstall the shifter handle. It's the counter-sunk screw that goes into the side of the shifter on the right hand side. Without it, all the shifter wants to do is pull off. The part number is N0331651. Any help locating one of these screws would greatly appreciated! Thank you in advanced for all the help!
Old 07-06-2015, 01:04 PM
968 GUY's Avatar
Most of those type of screws are normal metric screws available at most any hardware store.
87 951 all stock exc. cup II's /94 968 6-spd, lowered,17in. RUF Speedlines, M030 anti- sways/ 94 968 Tip, Cup II's, otherwise stock
Old 07-06-2015, 01:20 PM
VOTS89's Avatar
+1 ^
My local Ace Hardware has a huge assortment of metric fasteners.
Bruce
1989 944 N/A
1995 Ford F150 4X4
2016 Infiniti QX-70
2016 BMW 1200GS
Old 07-06-2015, 01:53 PM
Take the shift handle with you and test out the screw before buying.
Old 07-06-2015, 02:04 PM
In the Fires of Hell.....
kdjones2000's Avatar
It's an M4x8, if you dig into the Pelican website information.
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 07-06-2015, 02:06 PM
I believe the Violent Femmes had a song about that...
Old 07-06-2015, 02:18 PM
Thanks for the info guys! Good idea on taking the shift handle with me and on the size of the screw. By the way, this part has been discontinued and no one carries replacements just for future knowledge. Thanks again y'all!
Old 07-08-2015, 07:52 PM
