PorschePeter440's Avatar
MPG Gauge Interchangeability
Hi, I'm looking for a new instrument cluster for my '87 and I was wondering about the interchangeability of the MPG gauge. If I were to put a cluster from an 85.5 or 86 into my 87 would the MPG gauge work? Doing some research I came across a couple links indicating it should but I was hoping for some additional input so I could be 100% sure. Thanks!
Old 07-22-2015, 03:06 PM
You can look at the schematics at google: "vol4-electrical.pdf" to compare...
Curious why you are changing the cluster instead of individual gauges?
Old 07-22-2015, 03:18 PM
Will do. Thanks.
A previous owner not-so-tastefully customized the current cluster, broke off mounting tabs, removed all of the light reflecting components, spilled glue across a gauge, and broke several odometer components. At this point everything but the temperature and fuel gauge would have to be replaced, so it's easier just to replace the whole thing.
Old 07-22-2015, 04:25 PM
