O2 sensor problem?
OK guys - help me figure this one out -
I have a persistent problem of stalling when the car has not been driven for a while - It starts fine, then about 30 sec. to 1 min. later, it'll shut off. It can take a fare amount of cranking to restart. May repeat a couple of times. Once warm, the problems disappear and the car drives like everything (sensors, etc) are o.k. It did the same thing in the summer as it is now doing in the winter. It is kept in a garage for the most part when not driving.
My guess is that it is when the 02 sensor gets warm enough to kick in, it's not doing it right, until after the engine gets warmer.
Any advice on how to check the O2 sensor and/or other potential causes?
Thanks in advance.
Old 12-19-2002, 12:01 PM
todwic's Avatar
Send a message via AIM to todwic Send a message via Yahoo to todwic
Unplug O2 sensor when this happens and see if problem is still there.
*Disclaimer: The person above is actually dumber than he appears.
my web site Torque values maintainance and repairs lots of my rebuild pics weights and measurements
'84 944 auto/ps/ac/cc
'86 951
Providing ignorance one post at a time.
Old 12-19-2002, 02:25 PM
todwic's Avatar
If you had a california car, the O2 sensor would be heated. If it has one wire, not heated, if 3 wires, heated.
'86 951
Old 12-19-2002, 02:30 PM
todwic's Avatar
Could also be your Aux Air Valve.
'86 951
Old 12-19-2002, 02:31 PM
I'll try the unplug trick first (non-CA model) - the aux air valve was my other thought. Thanks for your advice.
Old 12-20-2002, 07:16 AM
