1QuickS's Avatar
Handling comparison between 944 & 911
I'm still getting familiar with my 1988 944S which will become my new toy after I sell my 67S hot rod. My 67 weighs 2000 lbs & has a 210 HP 2.3 liter engine and has Delrin/shperical bushing suspension pivots, re-valved Konis & revised spring rates. It is visceral & quick.
The 944 has yellow Konis, 7" & 9" rims with stiffer springs & sway bars. It feels fat & lazy on the road.
I'm thinking a diet to remove weight & installation of polybronze bushings & other low compliance suspension goodies to improve responsiveness.
Comments from owners of sports purpose 911s who also own a 944 with suspension upgrades would be greatly appreciated for the comparative comments between the two cars.
Paul Abbott
Weber service specialist
www.PerformanceOriented.com
Old 07-31-2016, 03:26 PM
petrolhead611's Avatar
Send a message via AIM to petrolhead611
You will have to get rid of a huge amount of weight to get it down to the same weight as your old 911. You bought the wrong model of 944, should have been a Turbo if you wanted equivalent power to weight. The 944 is from a different era to the original 911; the 944 shell has crash resistance in built which is heavy in itself, has more toys than an early 911, has slightly usable rear seats, and considerably bigger trunk. What did you actually expect?
1986 924S bought new. Now used for AutoX and street.
Chipped, throttle cam, highflow filter in original airbox/snorkel, 14mm rear sway
Hyundai Ioniq hybrid daily driver
Vindicator Vulcan V8 spyder, street legal sports racing car
(300hp,1400 lbs kerb weight) used for sprints on circuits, and hillclimbs
Old 08-01-2016, 01:30 AM
1QuickS's Avatar
Something a little more responsive than what I have. My 911 is too much for general driving, not to mention it is a "collector car & garage queen" so a tweeked 944 should fit somewhere in-between hot rod 911 & stock 944.
Paul Abbott
Old 08-01-2016, 08:36 AM
It also comes down to how you define "handling". The '88 Automobile mag article reviewing the '88 911 Turbo vs '88 944 TurboS is pretty good for comparing their handling. Subjective driver-impressions along with objective track racing. The 944 TurboS was 2-seconds/lap faster than the 911 Turbo when driven by Derek Bell. That's about 1 football-field ahead each lap; a significant difference. And the 911 Turbo had superior power-to-weight as well. However, that doesn't affect braking or cornering.
I don't think you'll ever get the front-end responsiveness of a 911 in a 944 due to the difference in weight-distribution. The larger polar moment-of-inertia with the engine & trans at opposite ends lead to great stability at high-speeds, but slows down turn-in response. This of course, is a very subjective area and personal preference.
Old 08-02-2016, 03:22 PM
There shouldn't be that much difference between the weight of the two cars, my bone stock '83 944 weighs in at 2175 pounds. Throw out the spare tire and buy some Plexiglas and you could beat the 911's weight.
Thanks for that! It's exactly what my gut feeling has been on the subject, good to hear it from you too!
Old 08-03-2016, 03:06 PM
Toofah King Bad
Rasta Monsta's Avatar
Is that like, Canadian pounds?
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 08-03-2016, 04:58 PM
flash968's Avatar
lol - yeah - that one caught me too. a few hundred short
as for handling, let's make sure we are using the right terms. there is a big difference between handling and cornering. handling is how a car handles weight transfer and transitions. cornering is how well a car goes around a corner.
Old 08-03-2016, 05:25 PM
Canadian pounds are called kilograms!
I weighed the car with me in it one axle at a time on the truck scale on the highway. 500kg on the front axle, 510kg on the rear axle for a total of 1010kg. 2.204 pounds /kg=2226lbs minus me at 240lbs is actually 1986lbs.
Hmm! Got a different result this time.
What do your 944s weigh?
Old 08-04-2016, 03:36 PM
racer's Avatar
What are the current spring rates? What size tires?
I came from track prepped 914's and 911SC.
I found my 944 to be very neutral, even stock, but soft. For AX I had to learn to slow down my inputs and give the car time to respond. Once I relearned how to drive it stock it was fun again (but yes, heavy).
I had an opportunity along the way to drive an older prepped 944. IIRC, the car ran 250# springs and 30mm tbs with M030 sways from either a 944T or 968. Night and day difference, but still didn't beat you up on the road.
It is a very different car than your early 911 (or 914) due to the weight and limited power. That said, there are TONS of upgrades available due to the 944 race series. want 600# springs? done. Want double adjustable shocks? done.
imho, while keeping it comfy on the street, you aren't going to pull more than 100# out of it easily. The structure of the body is just a lot heavier than your 911.
As to OPRN, US spec 944's are 2650-2900lbs.
Past:
2000 Boxster 2.7, 1987 944, 1987 924S
1978 911SC, 1976 914 2.0, 1970 914 w/2056
Old 08-04-2016, 03:44 PM
1QuickS's Avatar
I think it is the high polar moment that has me put-off so much; that and the weight.
Paul Abbott
Old 08-04-2016, 09:06 PM
You guys are correct, just checked the owner's manual and it says the curb weight is 2778lbs. The truck scale on the highway is out to lunch!
Old 08-07-2016, 06:42 PM
I weighed mine on the truck scales at the coal company I used to work for many moons ago when I weighed about 225 (man, I wish I could get back to that again LOL) and me and the car weighed in just shy of 2900lbs. These scales had recently been calibrated by the VA Deparment of Weights and Measures about an hour before so they WERE dead on the money accurate or they would have shut the scales down.
Old 08-10-2016, 10:36 AM
Banned
thats because the 944 is ~900lbs heavier.
if you want that feeling, i'd keep the 67. making a 944 feel that way will be tough to do.
my mr2 smokes my 944 in handling (so does my miata). 944 is a far better cruiser though.
Old 08-10-2016, 11:01 AM
CatsEyes's Avatar
I've had a 911 and two 944s (in sequence) for the last 3-4 years. I find I have to adjust my driving techniques radically between the two cars, every times I switch. Polar opposite in some ways.
My 944 is set up for street rather than track, and the tyres are lousy (so few choices here in 15", and I love my Fuchs!), so it's probably not a fair comparison. But yes, the 944's handling initially feels very soft and squishy after the 911. And the steering not nearly as crisp. Much more GT, as it were.
My simple rule of thumb for adjusting to the 944 after having driven the 911: enter corners in the 911 without any throttle, turn-in throttle-less, and apply throttle progressively through the corner, noting the apex.
But in the 944 brake well before the corner, and accelerate through it, continuously. The more throttle, the better she corners!
That way the two cars are both fun, each in their very different way.
Of course, more knowledgeable people here will probably have much better technical suggestions...
1980 911 SC Metallic Blue Euro spec, 'Greta'; 1986 944 Euro spec Light Bronze Metallic, 'Sabine II'
1986 944 NA Euro spec Guards Red 'Sabine I' - RIP, gone but not forgotten
'Hell is previous owners.' (anon.)
Old 08-16-2016, 05:02 PM
wayner's Avatar
Try measuring the weight of that rear glass separately!
SOLD - 914 wide body hot rod
Old 08-16-2016, 05:14 PM
Toofah King Bad
Must disagree with cat...944 loves to trailbrake.
Sent from my Nexus 6P using Tapatalk
Old 08-17-2016, 12:58 PM
TibetanT's Avatar
I have never, ever asked a woman what she weighs.
Ed Paquette
1983 911SC
1987 944S
1987 944 Manual (Donated to the Nat. Kidney Foundation)
1987 944 Automatic (Recently sold to another Pelican)
Old 08-17-2016, 03:23 PM
..or tell them, 'don't eat that'
Old 08-17-2016, 06:48 PM
White and Nerdy
Tervuren's Avatar
I've owned and driven multiple 944's, early, late, 3.0L, etc.
They each had their own driving style, on top of different options or modifications, is the general wear the car has gone through.
If you really want to crispen the car, add a X brace between the rear seat belt points, add a lower and upper front strut tower brace. The factory alignment is incredibly docile settings for the front, give it a little camber, an remove front toe-in to the point of near neutral.
After the above is done, see what you may need to do for wheel rates sway bars, and shocks.
Shadilay.
Old 08-17-2016, 07:08 PM
