Tach Not working
Ok, so my tach USED to bounce when the battery was low, but has never worked.
Lately, I replaced BOTH of the crank/reference sensors. Now the needle doesn't event jump when the battery is low. I have tested the gauge itself and it does work. (tested by putting into another car!)
Any suggestions?
Old 09-29-2016, 02:52 PM
curtisr
curtisr's Avatar
Wiser men than I will tell you to clean your grounds, grounds, grounds.
There will be a connection at the coil you can check.
Lastly, it's easy to access the gauges whereupon you can clean the connections with deoxit. Gauges - Removing Late 944 (1985.5 and newer) Gauge Cluster
1977 924 Guards Red (parted and sold)
1987 924s Alpine White (sold)
1987 924s Kopenhagen Blue (my Lowencash tribute track car -- sold)
1987 924s Garnet Red (currently becoming Lowencash II)
1982 928 Silver (sold)
Old 09-29-2016, 06:25 PM
Does the car run? If so, speed/ref sensors are fine.
The tach is driven by the DME. Check the wire going through a 4-pin connector between the DME and tach.
Old 10-01-2016, 07:48 PM
Car runs like a scalded dawg!
I will check 4 pin connector at DME tomorrow - Thanks
Old 10-08-2016, 08:29 PM
I am sure I have missed a ground..... someplace...... but can check again.
The gauges have been in, and out, a few times - especially when I recovered my dash. That's also when I checked the gauges on another car and found the tach worked,
Old 10-08-2016, 08:32 PM
911tracker85's Avatar
I gave up trying to find the wiring problem on my DE 951 tach. and rarely look at the tach with the shift light flashing telling me when to shift.
had this little tach intended for another purpose.
Bob Cox
78 930 clone project car.
87 924S resurrect at some point.
84 928S, Ruby Red linen/brown interior - sold
86 944 turbo my new DE/track car - sold
Old 10-09-2016, 06:45 AM
Its not that I need it, or would even use it per say - just nice that if its in the car, it SHOULD work.
My OCD I guess.....
Old 10-09-2016, 06:49 AM
If you have scope, check the signal come out of DME #21 a green/black wire. It should be open most of the time with a grounding pulse when the coil is fires. Re-check this signal at the instrument-cluster connector to make sure that the wiring is OK in between.
Old 10-10-2016, 01:04 PM
