Scott R's Avatar
Idle speed set screw backs out!
I have been looking for an idle speed problem for months now. I would set it and after a few miles it would creep back up again.
I finally marked the screw position and depth and drove it around a bit, sure enough it is un-screwing itself while I drive!
So can I just put "Lok-Tite" on it? Or should I replace the screw?
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 01-14-2003, 05:40 PM
I've lost two of them on different cars, when I replaced them w/ new ones(I had to, couldn't find 'em!) they didn't back out anymore. I'd just recommend you to try something like a really light grade of loctite that would just give it a little bit of resistance. I have some, just don't recall w/ # or color they call it.
Old 01-14-2003, 05:57 PM
Hi,
I had exactly the same problem. I ended up putting a small 1 inch piece of wire through the slot in the screw and then bending each end of the wire down toward the throttle body. Then I put a small hose clamp around the cylindrical body that holds the screw. The hose clamp clamps the wire ends to the cylindrical body. I know this sounds half assed but it does not look bad and allows me to adjust the idle any time I want. I can post a picture if you need one.
Old 01-14-2003, 06:05 PM
Scott R's Avatar
I like that idea! You would not happen to have a pic would you? Thats kind of hard to visualize.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 01-14-2003, 06:16 PM
AFJuvat's Avatar
You can use a spot of loctite blue on it - just make sure it is high enough to engage the threads, but but not run into the throttle body.
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 01-14-2003, 06:32 PM
SoCal Driver's Avatar
Teflon plumbers tape.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 01-14-2003, 07:28 PM
todwic's Avatar
Send a message via AIM to todwic Send a message via Yahoo to todwic
duh! put a larger O-ring on it.
*Disclaimer: The person above is actually dumber than he appears.
my web site Torque values maintainance and repairs lots of my rebuild pics weights and measurements
'84 944 auto/ps/ac/cc
'86 951
Providing ignorance one post at a time.
Old 01-15-2003, 03:15 AM
I used blue Loctite on mine. It's been holding for several years.
Lawrence
1986 951
2002 SLK32 AMG
1987 328GTS
2011 528i
Old 01-15-2003, 04:52 AM
If you are talking about the screw that adjusts the position of the cam (for the throttle cable), when mine got lost, I got a 5mm screw from Lowe's hardware store, and a small coiled spring. I cut the screw length to fit with enough room for the spring. Put the spring on the screw and put the screw on the throttle body. This keeps enough tension on the screw so it doesn't back out. I think the screw was 20 mm long, and I had to remove about 4 mm so that it would fit.
Good luck.
Stay Posted - more to come.
Old 01-15-2003, 07:56 AM
Scott R's Avatar
No it's the brass screw in the top of the throttle housing.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 01-15-2003, 08:07 AM
Here is a schematic, I could not take a real picture because my camera batteries were dead.
Old 01-15-2003, 10:14 AM
chapstic2001's Avatar
Send a message via AIM to chapstic2001
SoCal took my idea. Plumber's tape would be best. Or if you are in a bind use a pen cap. Wedge the bastard in there. Just make sure it isn't blocking off all the airflow. Now that would be down right silly.
'08 BMW e90 335i 6MT stock [aka 'take two']
'12 Dodge Durango [family hauler]
'86 951 (K&N Cone, Welt Chips, Tial, Zeitronix, P&P O-ring PH Head, WFHG, AFPR) [in storage]
Old 01-16-2003, 02:47 PM
Scott R's Avatar
I used a combination fix. First I did as Todwic suggested and replaced the rotten O-ring, and then just for the added security I used the teflon tape. It's holding now.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 01-16-2003, 03:49 PM
Roger Hall's Avatar
First replace the oring, then try the teflon tape. If that fails go tho the junkyard and pull a couple from some old Volkswagon's. Thats what I had to do when mine blew out. However I think mine blew out because the engine was having vacum, fuel injection, and electrical problems. As I fix the problems I can turn the idle screw much further in, and it idles smoothly at 950 rpms.
Roger Hall
81 924 N/A
Some people are like Slinkies. Not really good for anything, but you
still can't help but smile when you see one tumble down the stairs.
Old 01-16-2003, 07:04 PM
