A few small issues
Ok so on my 88 944 N/A the cooling fans will come on while the car is completely off throughout the night and drain the battery. Should i just replace a fuse or wire them into a switch under the dash? Also, i have an awful belt sqeal any time i go anywhere in between idle and full throttle. I do believe its the AC or Alternator thats causing the belt squeal. The timing belt seems to be in good condition and was routinely replaced around 10k miles ago. But, can i just put dry graphite lube on the belts to stop the squealing?
1988 Porsche 944
1979 MG Midget
Old 03-23-2017, 06:53 PM
If the fan is not turning off it is probably the fan sensor in the radiator. The squealing belts are probably loose and need adjustment.
Old 03-24-2017, 02:39 AM
A quick way to tell if it is a loose or glazed belt versus a bad bearing is to watch the battery gauge. If it jumps around while the squealing is going on and then jumps up after the squealing stops you have a loose or glazed belt
Old 03-24-2017, 07:54 AM
944 addict
mytrplseven's Avatar
Send a message via AIM to mytrplseven
Temp switch in the radiator is faulty. Common failure item. Rub bar soap on the belts to see if the noise goes away. If so, tighten or replace the belts.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman.
Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved.
Old 03-24-2017, 01:29 PM
