overkill's Avatar
Send a message via AIM to overkill
If I install a Borla muffler and,...
... keep the stock exhaust pipe diameter, will I loose back pressure? I also have a some what of a free flow CAT too. Will I loose backpressure If I have a free flow cat and a Borla muffler using the stock exhaust pipe diameter?
{1987}944S - (SOLD).
Old 02-01-2003, 08:02 AM
ae1969's Avatar
Send a message via ICQ to ae1969
You will loose some but not much that will make a difference.
If you want to see how gutless an NA can be. Pull the exhaust out in front of the CAT and drive it around (it will be a little noisy). You will be lucky to get it up to 60 mph.
Now go and fix your head already.
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 02-01-2003, 08:28 AM
JH924S's Avatar
Send a message via AIM to JH924S
huh since i have everything but my exhaust manifold ill have to try that for fun i did run it whle the cat and all was off and man talk about noise an open pipe harley had nuttin on it
1987 924S black on black , does it get any better?
Old 02-01-2003, 09:57 AM
You can install a Borla, but the engine still won't run without the head on..let's get it running properly first??
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 02-01-2003, 10:55 AM
overkill's Avatar
HA HA HA, true.
Old 02-01-2003, 11:53 AM
Overkill. I put a B&B cat back system on my 87 944S. I really did feel a bit more torque in the midrange. I was once told by B&B that the "S" needs very little back pressure and runs better than other 944's with less back pressure. be sure to disconnect the battery so the benifits of the exhaust will come into play sooner. If you do not it may take several hundred miles for the DME to adjust and make full use of this mod.
- Ross
944S/968 conversion
Old 02-02-2003, 12:54 AM
overkill's Avatar
Where can I look at some B&B exhaust systems? Do they have a site?
Old 02-02-2003, 06:25 PM
