Question Problem Removing Ignition Switch
I want to replace the ignition switch in my 944/1. Everything is apart and disconnected up to the point where the switch housing should slide out off the steering shaft, but it won't move. The key is in the ON position and I can turn the wheel 90 degrees and more, so I don't think the shaft is locked. What am I missing? Could there be something still to unfasten or disconnect? Could the bearing race be frozen to the shaft? Suggestions and ideas please!
Old 08-13-2017, 10:42 AM
the actual ignition switch only has one little screw holding it in.
are you trying to remove the whole cast aluminum switch housing? did you remove the pinch bolt on the left hand side?
Old 08-13-2017, 11:15 AM
This is for the whole die cast switch housing. I haven't reached the switch itself and its single mounting screw. Yes, the allen bolt is removed from the left side.
Old 08-13-2017, 12:54 PM
I know it's not very classy but I'd probably just use a gear puller to pull it off.
Old 08-13-2017, 01:07 PM
did you remove the black plastic sleeve around the shaft, its like a spacer to hold the steering wheel a cetain distance from the switch assy
Old 08-13-2017, 06:06 PM
Yes, the plastic spacer is off.
Old 08-14-2017, 08:38 AM
porschetub's Avatar
Punch it out from the back with a socket extension,just replaced my switch,make sure all the wires are out of the way...ok.
1985 944 2.7 motor,1989 VW Corrado 16v,57 project plastic speedster t4 power,1992 mk3 Golf,2005 a4 b7 qt avant 3.0 tdi,1987 mk2 Golf GTI,1973 914,2.2t to go in.
Past cars, 17 aircooled VW's and lots of BMW's
KP 13/3/1959-21/11/2014 RIP my best friend.
Old 08-14-2017, 08:53 PM
Back from Beyond
Got the shear bolt out? If so, insert a large flat screwdriver where the shear bolt clamps the housing and drive the screwdriver in with a hammer. Gently. The clamp will spread slightly and should slide right off the steering shaft.
Old 08-15-2017, 11:34 PM
Would this be an extension on a handle or just held in hand? I don't think there's room to get my hand in back of the housing while holding a socket extension, but will see. Thanks.
Old 08-16-2017, 11:24 AM
Yes the bolt is out, the headless allen bolt. I can rotate the housing right and left slightly and it doesn't seem to be binding at the clamp side, but there may be something going on there that I can't see. Thanks.
Old 08-16-2017, 11:29 AM
Thank you. This is what it took. I had to use a gear puller. The housing was just very snug on the shaft. Now the upcoming problem I see is getting the connector on the new ignition switch. There isn't much length of cable to work with and little room to get fingers in there. Will see.
Old 08-22-2017, 11:57 AM
